I recently purchased a used 460 that I plan on swapping out my 351m for. I have an np435 manual transmission, and the engine I bought has a flexplate on it. I am trying to find out which flywheel I need, as I don't know if the engine is internally or externally balanced.
the engine casting number is D1VE-A2B.
The head casting number is D3VE-A2A, but thats only 1 side, I was unable to locate a number on the other one.
any other info on the engine or swap would be helpful as well.. thank you
-Tyler
Reason: forgot head casting #
