Engine is out...what else should I have done?
Old 10-04-2006, 01:20 PM
kne831's Avatar
kne831
kne831 is offline
I currently have my 1985 300 at the shop. I'm having them pull the engine out and basically re-seal the whole thing since oil is leaking from every seal. I was wondering what other stuff should I have done since the engine will be out? I was thinking maybe the oil pump , water pump...
What do you guys suggest? I figure with the money I'm going to be spending, I might as well go the distance.
Thanks.
Derek
Old 10-04-2006, 05:18 PM
Steamir's Avatar
Steamir
Steamir is offline
Did you have them check the compression before they pulled it? How many miles were on it?
I would definitely replace the oil pump/screen and the water pump. Since they're both inexpensive.
Hopefully your compression was fine and you won't need rings/bearings.
Old 10-04-2006, 08:33 PM
kne831's Avatar
kne831
kne831 is offline
The engine has 110,000 miles. No problems with the compression thankfully.
Thanks for the reply.
Old 10-04-2006, 09:38 PM
hoxiii's Avatar
hoxiii
hoxiii is offline
If it's a manual and it was leaking oil badly, i'd put a new clutch in there to be safe.
Justin
Old 10-04-2006, 10:58 PM
kne831's Avatar
kne831
kne831 is offline
Justin, good call. That's exactly what I was told at the shop. It is a 4spd and it was definitely having issues shifting, especially when I downshifted to 2nd gear.
Old 10-04-2006, 11:15 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,727 Likes on 1,410 Posts
Timing gear set.....
Old 10-06-2006, 04:52 AM
headcustodian's Avatar
headcustodian
headcustodian is offline
Freeze out plugs. with out a doubt.
