'96 300i6 Rear Main leak
Make absouletely certian it's the rear main. I just replaced the rear main in my 92 that I was CERTIAN was the leak. Well guess what? the %&(^ still leaked. As it turned out the back of the oil pan gasket was what had been leaking buckets.
The oil pan I had fixed in 3 hours, the rear main took me the better part of a weekend.
Pull the little dustboot from the side of the bellhousing and inspect the clutch and pressure plate with a flashlight. If it's dry you're OK if it's oily then you'll probably already need at least a new clutch disc.
You were right, it is the oil pan gasket. My mechanic gave me an estimate of $65 parts and $370 labor. That seems a little high but he mentioned having to raise the engine a few inches to do the repair. If that's the case then I can understand the labor cost. Did you have to do that, and if so, does the price sound about right to you?
I've done this on my 95 F150 and my dads 92 F150. Both times with the engine in the truck. The engine does need to be jacked up two or three inches to clear the cross member when removing the oil pan. Its not hard at all. Remove the two nuts that hold the motor mounts to the frame perches, and I also removed the transmission mounting bolts. Jack the transmission up and from there I had plenty of room to get the oil pan out. Remove the oil pan bolts, drop the pan. Remove oil pump and pick up tube and drop into pan. Thats it, and reinstall in reverse order making sure the mating surface on the block is clean. Hope that helps.
All I had to do was remove the fan shroud (actually mine was already missing) Remove the two nuts from the motor mounts. Place a floor jack underneath the crankshaft pully and jack the engine up untill the EGR valve came into contact with the wiper motor. That's all I had to do to get access to remove the oil pan. The manuals say you have remove the oil pickup tube, I did not have to do this.
Like I said I timed the operation and it only took me 3hrs and I kinda took my time. My felpro gasket kit and oil from Oriellies only cost me $35 So unless the shop is charging you $120 per hour for labor The quoted price does in fact sound rather steep. Have you concidered going DIY? Cause I was rather tickled with how easy the gasket change was on my 92 4x2. If you can change you're own oil you can ace this project and save almost $400
Originally Posted by quicklook2
krochus, you did you mean you replaced just the gasket with the pan still in vehicle, right?
no way you took the oil pan completely out of the vehicle without taking the oil pump and screen out first.
i did this job and had to drop the oil pump into the pan to remove and replace it.
Did you make certian that the #1 cylinder was on TDC, Giving a little more clearance for the oil pan at the front of the crankshaft? And just how high did you raise the engine? I literally raised mine to the point that any higher would be breaking things.
Lastly did you try to get the oil pan out before removing the oil pump ASSY, My pan didn't exactly fall out, But with a little creative wigglin and jiggling it came out none the less.
I get the distinct impression that you don't believe me.
Originally Posted by 1982fordf100
I had mine up really high too. I also removed the transmission mount. I remember that my egr valve was touching the wiper motor and the top of my transmission was contacting the bottom of the cab floor. I too almost thought I broke something it was lifted so high.
I had the truck on a set of ramps and then I had my floorjack with a board pushing up on the harmonic balancer to lift the engine.
But I really think that having the number one throw on the crankshaft up and out of the way is what gave that last few 16ths of clearance that allowed the pan to come free without removing the pump or pickup tube.
robjs111
10-02-2011 10:28 AM
adroc104
04-03-2003 08:27 PM
