97 expedition EGR high flow error
A P0402 means that PCM thinks the EGR is flowing at idle when it shouldn't be.
If it's actually flowing it will idle very rough and probably stall.
The common cause of a P0402 is a bad DPFE sensor.
I was poking around the dpfe sensor yesterday. I had it checked at auto zone and they told me it was OK. I didn't believe them. Their Technician's testing skills were suspect. He used bare allagator clips that kept shorting on each other and the can. I was appauled. Fortunately I looked over his sholder and got a good idea of what needed to be done.
When I got home I reinstalled the dpfe and used two multimeters to check the input and the output voltage. From what I was able to gain from my evesdropping was the reference voltage should be ~+5v. The output voltage should vary with engine speed;(or the pressure sensed within the DPFE itself). What I found was the input was close to the output voltage and there was little change with engine speed (+/-0.1v). It would make sense that I would get a high flow reading if the output from the dpfe was close to tthe input voltage at +5v.
Today I will go get a new one and hopefully my problem will be fixed although with the way my luck is running another code will pop up.
Thanks to all. I hope that this will also help others.
Inshock
Did I mention that I HATE EGR??? Crap design and expensive to maintain and a PITA to troublshoot.
Brad
That's really not a valid test. Figures, since it came from AutoZone. The EGR should not be flowing anyway except a highway speeds and then only when commanded to do so by the PCM. The sensor should measure the difference in pressure (vacuum) between the two ports. Therefore, the sensor output should not change unless there is flow through the EGR valve.
A new sensor has a very good chance of fixing it.
cuda, Can't do that if you have to pass emissions testing. Any CEl/SES and you fail.
Steve
Just askin' some questions...I am still learning the 5.4 obviously...heh
Thanks,
Brad
