1964 292V8 Distributor trashed
Old May 24, 2000 | 05:35 AM
truckin61's Avatar
truckin61
Old Jun 6, 2000 | 09:20 PM
Blue 64's Avatar
Blue 64
Hello
->Does anyone know what might be causing a distributor's internal linkage to jam up and break?
I have a '64 F100 w/292V8. I started overheating a while back, and a couple of weeks later I lost all power. --I replaced the distributor with a reman. unit.
This time, two months later, I noticed the timing hovering over 6-10 degrees and it actually jumped down to zero in a day or two. Losing power at sharp revs too. --I did look at the oil pump shaft, and it looked straight and clean. Now, the distributor linkage is clicking and about to break again.
-->As long as the #1 is TDC, and the rotor lines up and points are opening, does it matter where the distributor housing is with respect to the engine housing?
Thanks, I sure hope no one else has had to learn this the hard way like me at 75$ a pop! (And in the Kansas wheatfields is not the best place to get stranded.)
Blue'64
keywords: distributor distributer timing oil pump shaft overheat losing power
