ZF coming soon
I ran my 351W crewcab with an 89 mustang EEC, and cobbled together harness made of junkyard snips I've been collecting over the years, and within four hours of tuning I had it running very well. Shouldn't be to difficult. I went back to the factory harness and the 94 computer I mentioned because eventually I'll be running the 351W in something else using the factory bits, so I didn't want to shelve them and lose/cut/destroy them. Plus, I made a small profit on the mustang bits on ebay
MAF really is the only way to go. I've been experimenting running a bone stock EFI 460 using a MAF system and it's working out well. Once I finish the TT 500cid, I'm fairly sure I can get that running at least "okay" in one weekend, then tune from there.
If you were running that rich I would have lowered the fuel pressure with an adjustable regulator and see what happened. Or, downsize the injectors, or adjust the tables in the EEC, etc.
Lean is where it's at. Lean burn!
BTW, if you don't own a wide-band O2 meter of some kind, you might considering acquiring one and installing a bung in your exhaust somewhere. It's very, very difficult to properly tune anything without knowing with accuracy, how rich and lean things are at idle, under load, during WOT, etc.
A friend of mine has an 89 mustang with a supercharger (Vortech I think) and managed to get it running reasonably well. My wideband meter shoved in the tailpipe indicated he was running the car embarrasingly lean. What we did was tweak things so that we could smell the fuel coming out the tailpipe, then backdown from there.
The car went from yanking your head back from a standstill, to causing severe neck pain. We didn't dyno the car before and after, but there was absolutely no doubt there was a noticable, significant power difference. Instead of smoking tires in 1st/2nd and chirping on the rest of the shifts, he could smoke in third and wheelspin in 4th on the shift a bit. DOT tires of course. Slicks would have been much more fun
Engines require fuel to make power. Most people, not having too much experience in "tuning", often end up with reasonably lean settings and are not getting the power out of their speed parts that they should. For driving around town (lower RPMs) this is fine as you can enjoy some economy in MPG, however closer and into WOT you want the fuel to pour in so you can enjoy your ride even more.
Why do you think I'm building a 500cid, twin turbo stroker for my crewcab? Trucks are heavy and acceleration is fun. Of course I have to balance the fuel at lower RPMs so I don't have to build a shack to live in at the local fueling station.
For example, my old 1975 Dodge extended cab, with a twin-turbo 451 stroker, got very close to 20 MPG (17-19 was typical on the highway), yet from a standstill, with DOT drag radials, I could lift the front of the heavy beast off the ground for a two wheel launch in whatever direction the truck was approximately facing.
THAT was a fun truck to drive, and had much more tuning to go before I ended up bailing on the project.
I have a 91 F-350 4x2 crew cab with a 351w and the ZF, been a great truck, have 222,000 miles on it, getting ready to pull the ZF and open it up to have a look inside, figure it's about time. I did one other rebuild on the same ZF for a buddy, all went fine.
On to my question, I may not understand this, but, are you saying in the above posts that a 94 EEC can really wake up my 351 due to the timming curves, etc.?
I don't have a lot in the way of advanced tuning tools, but if it's some what a "plug and play" swap, it's sounds great.
Your thoughts?
http://www.zf-group.com/pdf/lightTru...sion_Chart.pdf
http://www.zf.com/na/defaultz.asp?lang=1&id=220
Scott - if you have a 351W powered 92-94 E/F series without an E40D, the 94 351W E350 "chassis" EEC or the E350 passenger vans EEC will give you a very aggressive timing curve as compared to other EEC's in hte 92-94 range. Probably because of the gross weight of the vehicle, and how those vehicles are used - constant acceleration around large parking lots - not highway cruising.
The difference isn't "amazing", it's not like adding turbos, superchargers or nitrious, but it is noticable by the "****-o-meter". Installing one definately gave my 400k mile F350 crewcab some noticable pep during acceleration.
If you buy a clutch kit from a dealer, you're probably going to get re-man parts, NOT NEW. See my photo gallery. There is NO advantage in buying a clutch pack from a dealer, at all. I had a dealer put a clutch in mine a year ago, and the parts I found when I had to go back after the rear main (wish now I'd have bought the tranny jack sooner) disk, and plate, had re-man stickers on them. Yet, they won't hesitate to charge you NEW REPLACEMENT PART prices, and do not differentiate between re-man and new at dealers now, especially on dealer installed parts. I got that straight from a service advisor when I chewed him out about not replacing a $15 rear main seal while the tranny was out and the flywheel was off for re-surfacing. I was chewing on him about the re-man parts, actually, and took the opportunity to add in the rear main which was obviously drooling at the time.
If you're gonna pull the tranny and get the clutch done, get the flywheel machined too. If the clutch has been slipping, you'll have carbonized goo all over the surface of the flywheel that's just going to wipe out another disk in short order. However, make sure the jobber uses a grinder to surface the flywheel, and it leaves no grooves. Again, a little detail I noticed after the dealer's clutch job. A really nice spiral groove in the clutch surface on the flywheel. Can't say I have much hope of this clutch lasting very long.
EPNCSU2006, I have a shifter for a ZF if you're still looking....you just need the actual stick that comes into the cab right? pm me if you're interested.
MustangGT221, dont know if you're still subscribed to this thread, but I still have that computer in my truck you sold me (small internet/world after all) if you want me to grab numbers.
I agree with paint too, when you pull that old 4spd out of there, take the extra time and money to get that flywheel resurfaced (I got mine done at local CarQuest), and check the condition of the ring gear, might need a new one of those..
I just did a swap like this, threw in a ZF 5spd where there used to be an AOD four-speed automatic. What fun she is to drive now!
I am debating right now about how much work to do on the clutch/flywheel if I went ahead and installed the ZF behind the 302. It probably wouldn't be very much longer than a year maybe before the 351 could be ready to install, and I'd want new clutch components when I install that, so it's hard to justify the cost of machining the flywheel and installing completely new clutch components if they are just going to be replaced again when I install the new engine. On the other hand, I don't want to have drop the ZF to replace the clutch before swapping in the 351 if I don't replace the clutch when I install the transmission. I also worry about the new clutch getting messed up while running behind the 302 from a rear main leak, etc. and have to buy a new one again for the 351. The clutch has a lot of miles on it (almost 170000) but is showing no signs of slipping or wearing out any time soon. Trying to do this on a poor college student budget is one thing, but I certainly don't want to half-*** the job and have to do it more than once.
As for the shifter, I actually need the shifting mechanism that bolts to the top of the transmission, not just the handle. The guy I bought the thing from used it on his big block ZF when he swapped engines.
I do have the shifter part that goes into the transmission, from where the stick connects, down to the ball that goes inside....I used the stick, thats why I was wondering. PM me if interested
