Ford Explorer '99 wont start
Old Oct 3, 2006 | 06:54 AM
ade's Avatar
ade
Angry Ford Explorer '99 wont start
My Explorer (99 Eddie Bauer) refuse to start. It will crank but will not start. Found out there is no power to the fuel pump, and injection system. Tested fuel pump directly with 12volts battery and it worked. Please help!
Old Oct 3, 2006 | 09:57 AM
aquanaut20's Avatar
aquanaut20
Not at my dsk right now so dont have my manual handy
There are a couple of relays in the power distribution box under the hood on the driver side. One for fuel pump and another for PCM. As both these circuits have no power I would be looking for a main fuse(also in this box). If your fuses are good I would test for a bad feeder wire into the box.
Old Oct 3, 2006 | 09:59 AM
aquanaut20's Avatar
aquanaut20
Just a stray though, do you have an alarm system on the truck, Some remove the power from the pump and ignition..
Old Oct 3, 2006 | 06:24 PM
marragtop's Avatar
marragtop
I suggest starting with the fuel pump relay. Also, don't forget the inertia switch. Both can cut the power to the pump.
Old Oct 3, 2006 | 06:38 PM
aquanaut20's Avatar
aquanaut20
Marragtop,
he said he did not have power to the injectors as well as the pump.
Old Oct 4, 2006 | 03:54 AM
ade's Avatar
ade
There is a door alarm system, which has been deactivated. The fuel relay is okay. we will try and check the inertia switch.
