Any good source for full rust replacement panels?
Old Oct 2, 2006 | 10:06 PM
broke33's Avatar
broke33
Ive got a 1991 F150 extended cab truck that Im trying to replce the cab corners on. I bought a set of corners from JC Whitney and when I tried to fit them to the truck, they are not fitting properly. They bent them incorrectly. Anyways I've now got my old cab corner cut off about 16" up from the bottom of the cab and I am trying to find a replacement panel for it. I have a brother that works in a Ford dealership parts department and he said that Ford no longer stocks the replacement panels for my year truck. Ford had a replacement panel that includes the entire cab corner including the extended cab window. Anyone know where I can find 1 of these panels?
Thanks
Old Oct 2, 2006 | 10:32 PM
Trickedout420's Avatar
Trickedout420
LMC truck
ive got a few panels from them and they fit perfectly
Old Oct 3, 2006 | 08:51 PM
alz's Avatar
alz
I need to do this also. How bad of a job is/was it?
Old Oct 3, 2006 | 11:46 PM
Bulldog66's Avatar
Bulldog66
Thanks
Have you checked w/ a local bone yard? There's several near my neck of the woods and they've came through for me on more than once. You'll have to do the normal refurbish to it - I'd suggest media blast.
LMC is your next option. They're a little pricey for my tastes, however, in some cases, they may be your only option. They sell quality parts as well.
Old Oct 4, 2006 | 06:59 PM
lostin90s's Avatar
lostin90s
I have both corners,the $ ones go, door to around corner and 12 " or so high .But You aren't in my neck of woods o well. Try raybuck.com They have about everything . Some bone yards do handle generic panels . Good luck
________________________
94 F150 XLT 4x4 SC LB Maf 302 E4od
