Sponsored by: Auxito
Trouble code P0133
Old Oct 2, 2006 | 09:05 PM
fordforay's Avatar
fordforay
Trouble code P0133
I have a trouble code P0133 that says 02 Sensor Circuit Slow Response (Bank 1 Sensor 1) I know I need to replace an 02 sensor but I am not sure which one. The parts store is asking if it is before or after the cat converter. Can someone help.
Old Oct 3, 2006 | 12:15 AM
Racerguy's Avatar
Racerguy
Bank 1 is the engine bank with #1 cylinder.....the passenger's side.
Bank 2 is the driver's side.
Sensor 1 is the front one, sensor 2 is after the converter.
Old Oct 3, 2006 | 08:19 AM
fordforay's Avatar
fordforay
Thank you for your help Racerguy. I got started down a wrong path here and have two different post. I wont do that again but I am wondering if I have a vacuum leak rather than a bad sensor. I hear a pop once and a while from inside the cab that I am assuming is a backfire and the truck shifts hard periodicly. It also has a mild spark knock under pressure. Any advise
tbush08204
Jan 20, 2016 07:29 AM
Brandon50394
Aerostar
Sep 18, 2012 01:43 PM
jennkent5454
1997 - 2003 F150
Nov 11, 2010 02:24 PM
69deville
3.8 & 4.2L V6
Jan 16, 2007 05:40 PM
kamsho
Jan 20, 2004 04:05 PM
