Sponsored by: Auxito
Tach for 97 Ford
Old Oct 2, 2006 | 07:16 PM
Dank_44's Avatar
Dank_44
Tach for 97 Ford
This post may have been done already, however i just joined and was wondering if it was possible to swap out a dash from a newer f-150 truck with a tach and install it in my 97 Ford F-150 XL ext. cab auto with the 4.2L. Is it difficult to do? Any information is appreciated.
Old Oct 2, 2006 | 08:39 PM
projectSHO89's Avatar
projectSHO89
It would be easier to just buy a new truck that already has the instrument cluster in it that you want.
Steve
Old Oct 2, 2006 | 08:55 PM
Dustin1690's Avatar
Dustin1690
It is possible maybe find a donor truck and rip all the stuff out of that truck then try putting it into your truck i dont know how to do it though ever think of those aftermarket tachs probably a lot easier to put in than a whole new instrument cluster..
Old Oct 3, 2006 | 12:23 AM
Racerguy's Avatar
Racerguy
Welcome to the forum Dank_44
If your truck has PATS (Passive Anti Theft System), with the thick key with the chip in it, after replacing the instrument cluster you'll find the truck won't start. You have to get your dealer to reprogram the keys to work with the new cluster.
Old Oct 3, 2006 | 05:40 AM
Lt_Dusty's Avatar
Lt_Dusty
If you can find a cluster with tac from a 97 or 98 with mechanical odometer, it is a direct swap. Plug and Play. No concerns with pats on a 97. It would more than likely have to come out of another truck with a V6 though.
