Tach swap question
Old Oct 2, 2006 | 04:52 PM
f100beatertruck's Avatar
f100beatertruck
Tach swap question
I got a good score at the yard today, Tach cluster with trip speedo, intermitent wipers and about a half dozen other odds and ends that I needed (air box, throttle cable... etc) for $30 !!!
Anyway, the tach came from an 84 Bronco with a 351. Any problems with putting it into a 302 EFI? I'm planning on just swapping the clusters.
Also how do you get the blasted ***** off the wiper and headlight switch?
Thanks
Old Oct 2, 2006 | 05:09 PM
davidsca's Avatar
davidsca
I believe you can use the tach/cluster w/ no problem. I don't think it would work if you had a L-6 engine, but V-8 you're OK. As to removing the pesky headlight swicth, you need to be limber. You have to get your hand behind the dash and on top of the switch box itself. Theres a little button on top of the headlight switch. Push it down and pull the switch arm out.
The wiper **** is a bit easier. There is a little friction clip on the arm that you can push in toward the **** and it will release the ****.
Hope this helps,
Dave S
Old Oct 2, 2006 | 09:09 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
It will work on the I-6 engines too.
The Factory tach has two grounds.
One is the comon ground, the other is only grounded on V8 engines. It has a 8 written on the printed circut and tach to show this. The 8 terminal is not-grounded on I-6 applications.
L-6 - I believe is a slant six designation.
Hope this helps.
Old Oct 2, 2006 | 11:20 PM
F150 hybred's Avatar
F150 hybred
Slant six? Isn't that a chrysler engine?
Old Oct 2, 2006 | 11:30 PM
andym's Avatar
andym
Yes it is, but the L-6 isn't a reference to it. It just means straight six.
Old Oct 3, 2006 | 02:00 AM
Piffery1's Avatar
Piffery1
Little spring clips on back side of *****. Depress clips to remove. I use long nose pliers with one jaw on each side of the shaft. A small flat screwdriver works, too. Once you get one off, it's easy to see how they work.
Old Oct 3, 2006 | 02:21 AM
srercrcr's Avatar
srercrcr
I've never seen any reference to the Ford 300 as an L-6. The I-6 just refers to it as an inline six. Before overhead valve engines, we had L- head engines....the so called flathead engine where the plug went into the head on top.
Old Oct 3, 2006 | 04:23 AM
davidsca's Avatar
davidsca
L-6 as in long six, inline. Short 6 would be a v-6. Just some terminology I picked up over the years
DS
Old Oct 3, 2006 | 04:04 PM
81-F-150-Explorer
Yes, that's it! The older flatheads were sometimes referred as L-6's
Sorry for the confusion, sometimes my memory plays tricks. It's not like it "used to was"
Old Oct 3, 2006 | 04:34 PM
f100beatertruck
Swapped clusters and presto! I've got a Tach now. I also added the intermitent wipers. No more clicking on and off during a light rain...
Also both those ***** have those little clips. Also I noticed that there is a little cutout by where you have to press.
Thanks
