window overspray cleaning
Old Oct 2, 2006 | 03:19 PM
Ronindog's Avatar
Ronindog
Whats the best way to clean glass that picked up some primer overspray to ensure you don't damage the glass with scratches etc, in the process.
thanks
Old Oct 2, 2006 | 03:55 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
Very carefully with a single edged razor blade held at a low angle.
Old Oct 2, 2006 | 04:04 PM
kenseth17's Avatar
kenseth17
Wet down the window with plenty of glass cleaner and use fine steel wool or scrape with a single edge razor blade. Removes fairly easily from glass.
Old Oct 2, 2006 | 04:19 PM
Ronindog's Avatar
Ronindog
thanks
to one and all, thanks for the feedback
ronindog
Old Nov 10, 2006 | 07:12 PM
mrl390's Avatar
mrl390
Use a claybar. The steel wool idea does work but leaves very fine scratches that cause glare at night when headlights shine on it.
Old Nov 20, 2006 | 07:32 PM
Carpainter29's Avatar
Carpainter29
Claybar works well for light overspray, but steel wool will work better. Lube with plenty of glass cleaner though....
