'66 - 2 inch drop
Old Aug 5, 2000 | 07:18 AM
desertcamel's Avatar
desertcamel
'66 - 2 inch drop
I have a 1966 F100 that I want to lower 2 inches in front. Does this mean I'll have to get lowered i beam axles? or will I get away with the 2 inch drop without affecting the steering geometry and tyre wear?
Old Aug 6, 2000 | 06:04 PM
FE427TP's Avatar
FE427TP
'66 - 2 inch drop
try www.aimind.com, they sell the dropped I-beams, I believe they keep the correct geometry as well
Old Aug 6, 2000 | 08:28 PM
fuzz's Avatar
fuzz
'66 - 2 inch drop
[font size="1" color="#FF0000"]LAST EDITED ON 06-Aug-00 AT 09:38 PM (EST)[/font][p]Desert
I have pondered this for some time now. I will do this to my 77 F150 this winter. As I see it, when you but the aftermatket dropped I-beams I believe that other problems arise. As I scope out my truck I see that the tie rod will interfere with the oil pan and the rear support beams that stabelize the I-beam would have to be modified as it seems that the tie rod passes thru these supports and a lower job would cause interference here also. I am a machinist. So my plan is to use the old I-beams and fabricate a plate that will get bolted to the I-beam/pivot end. This plate will accomodate a 3 inch drop with a set of bolts that the spindle will bolt to. By using half inch plate and good grade bolts I believe that I can go all the way to a three inch drob no problem. This should maintain good geometry as I am merely "slipping" the spindle assembly up 3 inches where it bolts to the I beam/pivot. The only disadvanntage that I can see is that the slot in the backing plate utilized for adjusting the brakes will disappear. Once I have the plates made it shouldn't take but 3-4 hrs to get the truck lowered. (knock on wood) Lowering by means of dropping a coil or so from the spring or compressing the spring is not good for handling or the tires. Also it looks bad.
Old Aug 8, 2000 | 12:06 AM
Nate_64's Avatar
Nate_64
'66 - 2 inch drop
jeeplj8
Sep 8, 2021 06:52 PM
69supercj
May 20, 2010 02:24 PM
boo-yaa138
Mar 24, 2007 06:59 AM
65-f100
Jun 14, 2005 08:52 AM
DrewV
26
Apr 18, 2005 12:59 PM
