is the clucth on a '89 bronco 2 adjustable? mine engages when you press the clutch pedal down about 2 inches i dont think this normal or does it mean my clutch plate is almost all the way worn out? any help would be great thanks.
I believe your '89 uses the same type of setup as my '87. It uses a hydraulic clutch with a concentric slave cylinder that isn't adjustable.
I'm not sure what you mean by "engages when you press the clutch pedal down about 2 inches." Normally one talks about the clutch engaging while the pedal is up and disengaging while the pedal is pressed down. If the clutch isn't slipping, I wouldn't expect you have any problems yet.
