1978 - 1996 Big Bronco
Leaking steering gear
Old Sep 30, 2006 | 11:45 AM
Buckwild807's Avatar
Buckwild807
Just noticed pretty good leak out of the bottom of the steering gear on my 92. Been searching and reading threads on the best options, which seem to be replacement of the seal or replacement of the whole gear. Any suggestions or advice? What about the best threads to look at? I'm sure the info is already here, I'm just not finding it. Thanks for any and all help!!
Old Sep 30, 2006 | 01:03 PM
greystreak92's Avatar
greystreak92
Buckwild807,
Welcome to FTE and the Big Bronco Forum. We will endeavor to get you the most accurate info we can muster. You might check the tech articles area of the site for information about the procedure for replacing the seal or the gearbox. Some folks HAVE already dealt with this issue and I am certain will be along to offer their advice.
Old Sep 30, 2006 | 08:47 PM
dwoodler's Avatar
dwoodler
As far as it goes - replacing the seal should get rid of the leak for the cheapest amount. But if your steering is loose and needs replacement anyways.... but it's more money and more time.
Old Oct 1, 2006 | 07:33 AM
BigRedBronc's Avatar
BigRedBronc
You can replace the seals on your steering gear and seal it up for a while. The problem is you will be under there again in a few thousand miles doing it again. The hole in the steering gear is typically slightly out of round when you put enough wear on them for the seals to fail. You can pick up a replacement steering gear for around 250.00 with a lifetime warranty, and it is quicker and easier to replace the unit than it is to replace the seals. Disconnect the fittings, disconnect the rag joint, drop the pitman arm, remove the bolts, bolt in new unit, connect everything, purge the air, done.
Old Oct 1, 2006 | 02:47 PM
donehojo's Avatar
donehojo
What ever you do, don't get anything from AGR. There stuff is junk.
Old Oct 8, 2006 | 07:18 PM
Buckwild807
Thanks for the tips! I decided to replace the gear and avoid doing the job twice.
brenthottle
Jul 11, 2014 06:02 PM
Quizzack
Mar 19, 2014 11:28 AM
kill_them_all
Jul 13, 2010 03:10 PM
madpogue
16
Jan 31, 2007 08:29 AM
