Is my Explorer dead?
Codes for the KOEO self tist will be output before any continuous memory codes.
Fix any KOEO codes first (in the order given), clear the PCM continuous memory codes, go for a drive, and then and only then tackle any continuous memory codes set.
If KOEO givea a code related to the temp sensor, then find out if the sensor is really bad or you have a wiring/connector problem. The sensor is nothing more than a resistor whose value changes as the temp increases. A good first shot would be to measure the resistance on a cold engine, then again on a warmed up engine. If it has changed, then one could assume the sensor if functioning to some extent. If so the go for the wiring/connectors. Measure the same at the PCM wiring harness to verify wiring/connectors. If it looks good there then most ikely the PCM is faulty.
In short, break the trouble down into its most basic elements and eliminate them one at a time. Once you fix one thing, retest the system again and repeat the process.
But, if you can get a good used PCM - I'd maybe try swapping it out first - if you still have all those same problems, it's most likely a wiring problem (harness has shorts, etc)
The paper clip deal is good for a single code, or maybe a couple - which might be all you have in the first place, and a good reader will tell you for sure.
Others have warned me against diagnosing the problem by buying new parts one after the other. There is more wiring and sensors and weird parts in this vehicle than in Battlestar Galactica...how many thousands of dollars should I pay to fix an unreliable design?
I might try to see if I can rent a reader or find a mechanic willing to come by and read the codes. I am fairly sure the codes will be the same, though, and no progress will be made.
Hopefully somebody will know the most likely cause and a magic cure can be found. The most likely cause approach seems the best way to go at it, don't ya'll think?
Now if anybody wants a truck that was literally mostly driven by an elderly couple and only has 85,00 original miles and looks new-ish for about $1,500 it's yours!
I personally hate throwing $/parts at a problem, until I diagnose the problem rationally
http://www.tradervar.com/cgi-bin/sto...&page=3145.htm
or this one
http://www.tradervar.com/cgi-bin/sto...age=cp9015.htm
Do yourself a favour, quit bitching about the help you are getting and/or percieving not to get, do some serious diagnostics.
Remember the Lord helps those that help themselves.
My 2 cents.
But if you want to "learn" how to fix it and diagnos it, it's really not that complicated and can be very rewarding once you get the "beast" figured out.
The PCM is just a computer running a program. It's got inputs and outputs just like a PC. It responds (outputs) based on the inputs given. Thus the engine control system is equiped with sensors for inputs and actuators for outputs. When all the parts are working togethre correctly, the motor runs nicely. I've got 180K on my motor now and it's got just as much poer as it did when I bought it new.
I've asked you to PM me your email before and I'd send you links so you can go learn this stuff. So far you've not responded. I'll try to post some links but I'm sure the posting gods will squash them.
Gbas - it's like everyone is telling you - you need to find out the root of the problem - we are all trying to help you, but you have to give us more than what you have given us, or it's really anyones guess - that's my final feeling on it, and I agree with aqua... I used to work in Tech support, and we'd always get people that would call us back, without even trying to make things better on there own, after we'd spend 1/2 an hour on something that they could have read in the manual - of course, now, you can't even call support for anyone anymore, unless you can speak whatever language they do - it's sad.
The codes by the paperclip method are the same codes a reader would give, aren't they? Why would a reader be better? It's just quicker, or am I wrong? Does it give more than just the codes?
The truck does not run anymore BTW. It has a new nickname based on the movie "The Gods Must Be Crazy"...it's "antichrist"!
I will read all the stuff you suggested and see if I can get more clues and learn where all those sensors are...
Again, thank you.
It's common sense that it would be VERY unlikely that you actually have 10 codes or however many, as legit codes, and the fault of the sensors, with a perfectly good PCM - but it's possible.
a decent shop will pull the codes for you, AND test the PCM - even if you have to tow it there - at least, then you'd know what's going on to start with.
If you have them pull your codes, you can compare what they find to what you found with the paperclip test...
I really think it's a very simple matter of just verifying that you have a good PCM in the Truck or not - you could try swapping it for another one, if it would be cheaper than having someone test it. either way, it's your first step I feel, as do many others that have followed this so far, and have told you their 2 cents worth...
http://tinyurl.com/mb25n
email the seller and ask him for the code on the computer. I'm not sure which numbers have to match up with yours, but I think MrSki already posted that info, or he could just post it again. If the numbers match, $45 ain't much to rule out your computer.
