Mounts and Brackets
Old Sep 30, 2006 | 04:21 AM
danfish's Avatar
danfish
Mounts and Brackets
I'm swapping a SB Ford 302 into a '55 Ford F-100, and need to know which are the best brackets and mounts to use for this swap? The mounts I keep seeing are just the two brackets (no frame cross member) and mounts, are these very sturdy and are these pretty commonly used?
Old Sep 30, 2006 | 05:35 AM
Caddy 53's Avatar
Caddy 53
There are several frame to frame tube style mounts that will work. I got mine from MID FIFTY.COM. I would sugest you request a catalog. Many fine parts available. There are other shop's and venders out there. Most are located in the west.
caddy 53 chuck
Old Sep 30, 2006 | 07:57 AM
fatfenders's Avatar
fatfenders
Stock front suspension? If so, the tubular style is a good one to consider. Available in that catalog Chuck just recommended.
Old Sep 30, 2006 | 10:14 AM
CharlieLed's Avatar
CharlieLed
I agree...the tubular mount from Midfifty is inexpensive, easy to install, and IMHO the best way to attach a load bearing structural member to the F100 frame.
