Actually there is a gap between them after fully tightening the nut.
Someone told me there is supposed to be a washer that goes on before the nut, but there was one there when I took it off and there is not one in the pictures in the Chilton manual.
Yeah thats not good, you should get a new crush sleave, and redo the preload so you don't destroy your gears. While your at it, take a pic of the problem so we can see whats going on.
thanks
crush sleave?
redo the preload?
Can you translate that into language the Chilton manual uses, I see nothing in it about those things?
