looking to replace an ignition control module on an 1988 f150 with a 302 any one know whatsize that socket is and where I might get tone to fix this truck thanks in advance for anyhelp
If you're talking about the TFI module on the side of the distributer they sell a special socket for it. Any good part store should have it. I got mine at pep boys and they never have stuff to fix my truck... I think Lisle makes it.
any one have an Idea on a hard start in the morning on an 88 f150.
this is all I have done .
replaced all 3 fuel pumps and all the sensors o2,map sensor, coolant temp.sensor . has new pulgs and wires cap and rotor and just replace the ignition control mod on the side of the distributor. after it starts it runs like a champ,made sure the timing is 10 degrees btdc pretty much stumped at this point anything I left out I might be able to try?
well your in the wrong forum but maybe the injectors are dirty. you could send them out to be cleaned or try cleaning them yourself or possibly run some injector cleaner through the tank
