Pertronix for 292V8 ?
Old Nov 22, 2000 | 06:24 PM
Kenny's Avatar
Kenny
Old Nov 29, 2000 | 09:23 PM
crew95's Avatar
crew95
should I try it? should I change the coil to a high voltage?
My 292 dosnt have a pointer for timing mark,Where did it go?
Old Nov 29, 2000 | 10:11 PM
jbhf250's Avatar
jbhf250
>high voltage?
>go?
Its a great No Point`s conversion!http://www.pertronix.com/ignitor.htm
Your stock coil will work.
Look in the junk yard for a replacement pointer.
__JOHN__Õ¿ö
Member-
"Crusin North" Car Club
Santa Rosa, Calif.
72 F-250
ICQ#6030753
Old Nov 29, 2000 | 11:21 PM
hpguy's Avatar
hpguy
I have a '64 F250 with a 292 v8, and I plan on doing the conversion as soon as the points need changed again. Although it will work with your stock coil, I plan on going with a higher voltage, high performance coil. I've also done the big-cap distributer conversion, being discussed in several different threads, and 8mm wires.
-Andrew
Nothing, and I mean nothing, stirs the soul, saying I'm a bad **** like lettin'em rip with a window shaking, fuel gulpin, carbon monoxide belchin, attention gettin, V-oh my LORD!-8!
Old Nov 30, 2000 | 07:43 AM
William's Avatar
William
Crew95, Pertronix Ignitor is one of the best and easiest improvement you can make on your 292. I'd leave the rest of the system stock for now unless it needs upgrading. I'd do the big cap and fat wires next. Followed by platinum plugs gapped at 60 and a mallory coil. I did this 5000 miles ago and have had absolutely trouble free operation since. 66 F100 390CI C6 SWB
William in Atlanta
