3rd 195* T Stat
Old Oct 1, 2006 | 11:06 PM
bigbrown84truck's Avatar
bigbrown84truck
just take the damn guess work out of it. go to advance auto parts and spend 15 bucks on a cheap mechanical gauge.
Old Oct 2, 2006 | 02:00 PM
headcustodian's Avatar
headcustodian
My 92 F150 has a showroom condition interior. I'll be damned if Im going to drill any holes anywhere for a cheap guage. Don't worry I'll figure it out all by myself. The End!
Old Oct 2, 2006 | 09:24 PM
Krochus's Avatar
Krochus
In that case I'ed just do like I'm gonna do and not worry about it. I know what temp range the engine normally runs at therefore I can surmize that if my temp gauge starts reading something diffrent then sumpin is up.
Sometimes you're better off not to worry about these things. Example: I once bought a nice 77 Datsun 280Z from a coworker with a toasted engine. What had happened is the OEM oil pressure gauge developed an odvious ground problem. Well they became obsessed with the oil pressure so they installed a cheap oil pressure gauge. Well that was fine untill a couple of weeks later that crappy nylon line running to the gauge got a hole rubbed in it pumping ALL of the oil from the engine and causing it to sieze. DUMB IDEA.
Old Oct 2, 2006 | 10:08 PM
rhetor's Avatar
rhetor
The range on the gauge is about as useful as wings on a penguin.
Don't trust that gauge at all. Borrow an infared heat gun, or just get an oven thermometer. Something, anything, that will give you a more accurate reading. It probably isn't running too cold.
Old Oct 2, 2006 | 10:33 PM
Krochus's Avatar
Krochus
AGAIN
Anyway I got the two tempsticks out that I had on hand an 150 and a 225. With the needle on the "N" the 150 tempstick will melt on the t stat housing the 225 does not.
That puts the temp somewhere between 150 and 225 degrees so no the engine isn't runnin too cold, In my case the heater in my truck just sucks.
Old Oct 5, 2006 | 03:11 PM
Argo's Avatar
Argo
Originally Posted by Krochus
:That puts the temp somewhere between 150 and 225 degrees so no the engine isn't runnin too cold, In my case the heater in my truck just sucks.
I know it may sound stupid, but check the heater lines on your truck to see if they are on backwards. If so, that can make the heater run cold. I did that by accident once with my 1996 F-150 about a year or two ago, when I changed all the hoses. After I switched them around (after a week of suffering in the cold) and I was overjoyed! I had HEAT!!!!
Old Oct 5, 2006 | 04:17 PM
Slow's Avatar
Slow
ok, so dumb question.. what is the right way around for the heater lines?
Old Oct 5, 2006 | 11:32 PM
Argo's Avatar
Argo
Hmm... I don't know. I'll have to take a look tomorrow.
Old Oct 6, 2006 | 01:36 AM
Slow's Avatar
Slow
actually I looked at my 300.. it has an arrow out from the head. So.. I'd guess you'd want the outflow from the engine where it'd be hottest to go to the heater.
Old Oct 6, 2006 | 04:48 AM
headcustodian
There is no right or wrong way to hook them up. What might of happened was when you pulled the hoses,you purged the air from the heater core. whithout even knowing it. This inturn allowed the coolant to flow freely through the core. A heater core is just a baby radiator.
Old Oct 6, 2006 | 11:07 AM
Slow's Avatar
Slow
hehe, after I posted that last night I was thinking about it and ya.. there's no right way
Old Oct 6, 2006 | 11:32 AM
headcustodian
Unless you put them on upside down. Right? yuk,yuk.
Just to let everyone know. I put a 16" elec. cooling fan on, set at 195*
1) Temp is now mid range
2) Heat is excellent
3) A little more power
4) Fuel mpg up 3.5 around town
The fan almost never kicks on. When it does it only draws 6.5 amps. If you could only see me smiling. I wouldn't be surprised if mpg picks up a little more once the puter relearns itself.
Thanks all
Frank
Old Oct 6, 2006 | 02:36 PM
  #28
Argo's Avatar
Argo
Probably was a bad fan clutch? Anyhow, you can indeed hook up a heater core wrong, on some cars and trucks, depending on their design. Mainly because of the exact reason stated earlier. Air can be stuck in the core and not purge when running the engine in some designs.
Old Oct 6, 2006 | 02:57 PM
  #29
Silver Streak's Avatar
Silver Streak
And some have restrictors or check valves in the hoses to keep them from flowing too much or from draining.
Old Oct 6, 2006 | 05:51 PM
  #30
headcustodian
I agree but, Those heater cores almost always have two different size inlets on the core itself. If not always. I also disagree with the fan clutch theory. I bought a new one and it did the same exact thing. All I kept hearing is, these motors always run on the cold side. So what I did was.I just took the fan off completely. Drove it for one full day. I put 90 miles on it,without overheating once. Temp stayed mid range all day at 70* outside temps. So I decided to put an elec. fan on for the really hot weather.
If you pay attention to any front wheel drive vehicle. You will notice how little the fan actually kicks on,and when it does. It's for a very short period of time. So my of thinking was to remove the fan. Whats nice about this is even in hot weather the motor will run cooler do to the cfm's the fan pulls. Its a win win situation.
Bottom line. It works for me,and hopefully someone else with the same problem.
