Starter Interlock?
Old Sep 29, 2006 | 07:25 AM
airman's Avatar
airman
Starter Interlock?
Hi, my first post.
A friend gave me a rather rough '76 F-100. The engine has been swapped, a 302 for a 289. The truck has an automatic trans. It cranked without problems before I removed the steering column to free up the frozen shift mechanism. Now it will not crank when I turn the key to start. It will crank if I jump the starter solenoid. It seems there is no continuity from the switch to the solenoid. Is there an interlock switch? If so where would I find it.
Thanks
Old Sep 29, 2006 | 12:18 PM
ford141's Avatar
ford141
There is no interlock switch that I am aware of, the only wires that go into the column are for the turn signals/4-ways, the horn, instrument light for the shifter, and cruise control if so equipped. I would suggest checking the wires at the ignition switch to make sure that you didn't bump something loose when removing/installing the column, if that's good, get a buddy and test the solenoid activation wire with your buddy holding the key to Start. If you have juice there at the solenoid, replace the solenoid. Solenoid failure is common on these old Fords.
Old Sep 29, 2006 | 12:30 PM
77460f150's Avatar
77460f150
I think the NSS may be located on the bottom of the steering column, make sure it was plugged back in after column installation. It may just need to be adjusted also. Try to move the gear selector to neutral or another gear (BE SURE TO BLOCK THE WHEELS AND APPLY THE BRAKE WHEN YOU DO THIS!!!) and see if it will crank, if so you need to adjust the NSS. -Ed
Old Sep 29, 2006 | 01:31 PM
ford141's Avatar
ford141
The NSS is located on the transmission, but you make a good point. If the linkage is not adjusted properly, it won't start. Sounds like a great starting point...
Old Sep 29, 2006 | 01:46 PM
77460f150's Avatar
77460f150
My 77's was on the column end, what year did they change to transmission? I thought it was 78. -Ed
Old Sep 29, 2006 | 02:33 PM
Mil1ion's Avatar
Mil1ion
Welcome to the site Airman
For standard transmissions the NSS is on the trans
For automatics the NSS is on the column until 1978 when it moved to the side of the trans.
He didn't say what trans he had.
I suspect the NSS or its wiring as well .
If it's an Auto trans. Try going back and forth between Park & Neutral to see if you can get it to turn over..It may just need adjusting.
If it's a standard check out the condition of the switch as it's down there with all the grease and grime and may need cleaning.'
Old Sep 30, 2006 | 12:30 PM
77460f150's Avatar
77460f150
In his 1st post it said "The truck has an automatic trans." -Ed
Old Sep 30, 2006 | 01:36 PM
Mil1ion's Avatar
Mil1ion
Doh ! Missed that obviously
Old Sep 30, 2006 | 07:20 PM
airman's Avatar
airman
Hey guys,
Thanks for all the replies. I'm glad I found this forum!
The NSS is located on the column. This one had all the wires ripped off, not even a recognizable wire connection left so I didn't think it was a switch until I looked more closely. I found the wires that were "disconnected" and spliced them together to get the truck to start. I know it will start in any gear now but that doesn't matter until I can get a gear to engage (another problem). The trans is a 3 speed automatic and it seems like the parking pin is engaged and the internal linkage is broken. It will not shift out of park. Any thoughts on this?
By the way I will need a new switch, and what is the gauge pin hole for?
Thanks
Old Sep 30, 2006 | 07:28 PM
Mil1ion's Avatar
Mil1ion
The gauge pin hole is for making the adjustment for the Neutral position.
The way it works is.
Loosen the linkage......place transmission in neutral...place gearshift in neutral...
Loosen NSS on column
Rotate the NSS until you can place a the drill bit right into the hole aligning up everything.....Now....Tighten everything back up..remove drill bit and the engine should start in neutral or park.
Beaverman
Oct 3, 2011 07:19 PM
ihateminimumwage
Electrical Systems/Wiring
Jul 30, 2010 12:31 AM
Ogrebonz
Feb 24, 2005 12:53 AM
Pat
Jan 27, 2001 02:04 PM
