5 speed
Old Sep 29, 2006 | 07:05 AM
78150's Avatar
78150
5 speed
My question is, will a 5 speed from a 87-96 style fit in a 78-79 f-150 2 wheel drive still keeping the original clutch linkage, or is the transmission a 1 piece unit in the newer ones. Also what is the best way to beef the rear springs with out affecting the ride to much. And what is the best fuel milage V-8 in your opinion for that truck with the 5 speed and ???????? rear gears, What is the best ratio for pulling and hiway? Thanks
Old Sep 29, 2006 | 10:22 AM
Digger6's Avatar
Digger6
You will have to switch to a hydraulic clutch to use the Mazda tranny that came in 1/2 tons behind 302s in 87-96. I'm not sure about the ZF tranny from the 3/4 tons. If you do go to the OD 3.73 gears would work well.
Old Oct 3, 2006 | 08:57 PM
solidrunner's Avatar
solidrunner
460 ZFs had mechanical clutch linkage. If you have a 351-400 or 460, you can use the 460 ZF and make your stock linkage work. Look in my gallery, I have some pictures of the ZF swap I did in my truck.
Old Oct 4, 2006 | 08:53 AM
T18skyguy's Avatar
T18skyguy
You can also put a NV4500 5 speed in your rig and keep the original linkage but you need an adapter from advance adapters. See my gallery for some pics of my swap.
Old Oct 4, 2006 | 10:36 PM
BCTom's Avatar
BCTom
https://www.ford-trucks.com/article/...nsmission.html
Here's a link to an FTE article on installing one behind an FE. On the trans forum some of the post have unkind things to say about the Mazda trans. FWIW.
Old Oct 5, 2006 | 12:39 AM
jmono's Avatar
jmono
Offtopic... But AMAZING truck. I love it.
