problem with taking down pipe off turbo
Old Sep 28, 2006 | 07:27 PM
zomowiec's Avatar
zomowiec
Trying to put new exhaust and i have a problem taking downpipe of the turbo loosen the bolt on the clamp and removed other pipes from dp but cant get it off. Don't want to really hamer on it afraid to brake the turbo. By the way is there a way to remove the tail pipe with a muffler from over the axle without cutting it and not raising the car really high, The car is 00 EX 4/4
Old Sep 28, 2006 | 07:43 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Hose it down with WD-40 and work it with a flathead screwdriver. Not hard, be patient and it will work loose.
Old Sep 28, 2006 | 07:47 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
if the clamp is loose, take a long prybar and set it on the clamp. then tap (not hit or smack) the bar with a large hammer. a few to a hundred taps and the clamp will pop off, usually in thirds.
Old Sep 28, 2006 | 07:50 PM
Uzumati's Avatar
Uzumati
As ar as the Marmon clamp spray it with a little WD40 and let is sit then take a flathead screwdriver and gently pry up un the three flange partitions. Once you get 2 loose the rear one usually will com on off. I just went through the "Marmon Clamp from H%$^" this last weekend
If you look just under the flat metal band you will see yje flange that is broken into 3 pieces
Old Sep 28, 2006 | 07:54 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I drove mine onto a ramp (right front and back tire) before starting my adventure. You can then, and only just work out the muffler and tailpipe section with some manipulating.
If your stock system is loose and hanging there, it makes the DP clamp doubly hard to remove. It's best to have someone below helping by pushing/holding/ cursing , or singing your praises. If you think getting it off was a treat, wait until you try the install. Just try it with out help. It can be done but why struggle?
Old Sep 29, 2006 | 07:41 AM
zomowiec's Avatar
zomowiec
Thanks guys i got it off but you were right puting it on with out help is crazy, but its on so now just the problem of taking the stock muffler and tailpipe form over the axle. I think i will save my self some work and just cut it
Old Sep 29, 2006 | 08:27 AM
aklim's Avatar
aklim
Or take the right shock off which you will need to do to install the new exhaust
