Installing new Flowmaster muffler
Old Sep 28, 2006 | 04:09 PM
5.4Varial's Avatar
5.4Varial
I just picked up a flowmaster 40 series delta flow muffler from e-bay so I'm ready to install it on my 99 F-250 with a 5.4. I went and got a 6 inch extension so hopefully that will be enough as well as clamps. The muffler part number is 943041, is this correct? What are the steps as far as yanking out the old one, I took a quick look and saw what looked like large bands holding it on how do those come off? I tried a search and didn't come up with much, Anything that might be helpful would be great. Thanks!
Old Sep 29, 2006 | 01:13 AM
jimbo beam's Avatar
jimbo beam
not sure what the newer trucks are like, but any time ive ever had to remove factory exhaust pieces they're always rusted together pretty bad. your best bet may be to get a hack saw or sawsall and cut the muffler off, have the new muffler and pipe flared at the ends so they'll slide over the factory pipe and then clamp or weld them together
Old Sep 29, 2006 | 10:55 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Heh...you should have seen how the frickin muffler shop installed my Flowmaster! The stock pipe is 2.5"OD, and the Super 40 I got was a 3" OD inlet. Well...instead of putting on an adapter, he decided to "eyeball" the muffler and fill in the 1/4" gap all the way around with weld! Ohhhh that pissed me off!
But that's not the end of it...
Before, when I cut off my factory muffler, I had to add an extension to get it past the cab so it would pass inspection. Well, I used a cheezy clamp from AutoZone, and added a 2' section of pipe from a friends old exhaust. Well...the guy cut it off 2" behind the clamp and welded the muffler there.
Now I have a gimpy-a** exhaust system with 2 clamps, a flimsy adapter, and a 3" muffler welded to to a 2.5" pipe. Oh man am I pissed.
Sorry for getting but I just had to vent!
Old Oct 5, 2006 | 11:31 PM
5.4Varial's Avatar
5.4Varial
Thanks guys. Does anybody got anything else that can help me out specifically.
Old Oct 15, 2006 | 08:19 AM
Mr. M's Avatar
Mr. M
I cheated and used the plasma cutter at work after hours. But a hacksaw or sawzall will do the job. Once you get the old one off the rest is gravy.
Good luck.
Old Oct 18, 2006 | 12:56 AM
scooterscott's Avatar
scooterscott
yeah, i've been going through some muffler issues myself, hopefully we'll both find some people that can give us a helping hand.....good luck
Old Oct 18, 2006 | 03:02 PM
fordguy55's Avatar
fordguy55
Exhaust info
Sorry to hear you got a 40 series flowmaster. I just took one off my son's Ranger that lasted less that 3 years. Had the same jacka** type of install with the 3" inlet filled with weld material. He had it done at Meinakey. I replaced it with a magnaflow stainless that cost about $60. The magnaflow actually had the same length as the factory muffler. Had to replace the cat to muffler piece too but required 2 adapters to make it work. Good thing too because cutting off the twin tails made them too short. The adapter made up the difference at the back. Anyway, about the time your 40 series rusts out, you'll be ready for the magnaflow. Nice deep tone without that annoying "blat" sound at WOT. Look at http://fulllineexhaust.com. You can customize your system with the parts and adapters they sell. Stainless is the way to go.
Old Oct 18, 2006 | 07:52 PM
RangerPilot's Avatar
RangerPilot
Stainless is also ridiculously expensive and unless you live in the north, where salted roads are common, not worth the money.
The Flowmaster 40 I previously had on my truck served me well...actually for that matter it was quite nice. I did the welding myself, took my time and used an adaptor. Don't blame the muffler company 'cause your welder did a half-assed job. If he's too lazy for not using adaptors, that's his fault for being lazy and your fault for using him, then allowing him to do it.
The Flowmaster 40's a good muffler, I ran one for a while (now I have no muffler), quite happy with it overall...expect your gas mileage to go down because of lead foot syndrom. The sound makes people happy.
And oh yeah...your Triton's about to sound like every other modified exhaust out there...
On topic: hacksaw or otherwise remove the old muffler, install the new one with adaptors, and have a shop weld it together. Not a painful job at all.
Old Oct 18, 2006 | 08:31 PM
fordguy55's Avatar
fordguy55
Flowmaster
Hmmm.. Looks like I stepped on a bees nest. I was actually just giving an opinion. Apologies for pissing you off.
Old Oct 18, 2006 | 08:58 PM
RangerPilot
No hard feelings, you didn't **** me off.
I guess I'm just partial to the Flowmaster and somewhat tired of people slamming it on here, namely those who don't run it or run a competitor's muffler and have no experience with it. I did not aim that comment at you specifically, and I'm terribly sorry if you took it that way.
Do take care.
Old Oct 19, 2006 | 02:58 PM
Patbo8's Avatar
Patbo8
Can I run dual exhaust on my Ranger Edge 2001 with two mufflers? sorry dont really know alot about what i can and cant do.
Old Oct 19, 2006 | 06:49 PM
RangerPilot
Yes...but there's a problem with that which may cause you to want to run a SI/DO (single in, dual out) muffler. Due to the design of the Ranger's exhaust, the exhaust manifolds combine into a Y-pipe which then goes to the cat converters, muffler, and tailpipe.
Since the cats are needed to pass inspection, you'll have to put another Y-pipe after the cats, split into two pipes, each with a seperate muffler and tailpipe.
The other option I mentioned was the SI/DO muffler, which would run the pipe from the cat into the muffler, then output two pipes to run to your choice location. It's definetly the easier of the two for the Ranger.
Old Oct 19, 2006 | 07:08 PM
Patbo8's Avatar
Patbo8
Smile thanx
Thanx for the help.
2FordTrucks
Oct 31, 2011 03:51 PM
biebs53
1997 - 2003 F150
Dec 10, 2010 07:00 AM
Eac95z28
Dec 16, 2009 11:52 AM
boxcar1974
Modular V10 (6.8l)
Aug 27, 2007 07:52 PM
dgfisher
Exhaust Systems
Jan 16, 2004 01:24 PM
