Another Oil Pressure Problem
Old Sep 28, 2006 | 02:47 PM
catmandu79's Avatar
catmandu79
I have been working on vehicles since I was 14 and have never encountered a problem like this! I have a 1969 Lincoln 460 in my 79 F250. When it is cold the pressure seems to be okay, as it starts to warm up the pressure will drop to 0 or close to it, then as it get closer to normal running temp the pressure comes back! Can someone shed some light on this weirdness?
Old Sep 28, 2006 | 04:04 PM
bronco521's Avatar
bronco521
are u running a wet gauge?sounds odd for an engines to do this.
Old Sep 28, 2006 | 04:39 PM
catmandu79's Avatar
catmandu79
At this time I'm running the stock elec. pressure gauge
Old Sep 28, 2006 | 05:23 PM
shortbed1's Avatar
shortbed1
You need to ck that oil pressure with a mechanical gauge to see exactly what it is doin, That electric gauge might not be reading right.
chuck
Old Sep 28, 2006 | 06:15 PM
WILDEBILL308's Avatar
WILDEBILL308
Yes I would check your oil pressure with a good mecanical gage to see if your original is working right. I bet it is the gage.
Good luck
Bill
Old Sep 29, 2006 | 03:50 PM
catmandu79's Avatar
catmandu79
I will check that out this weekend, Thanks!
