Sponsored by: Real Truck
Driver's power window up, no work.
Old Sep 27, 2006 | 10:05 PM
fordlovin's Avatar
fordlovin
I went to put down my window and it hesitated for a second and then went down like half way and stopped. Went right back up with no problem. All the other switches work and when push the put "UP" I can hear the motor and when I push it "DOWN" all I get is a click noise. Any help would be great!
Old Sep 27, 2006 | 10:22 PM
jake00's Avatar
jake00
I'd guess its rthe switch, I've had to replace mine 2x
Old Sep 27, 2006 | 10:36 PM
fordlovin's Avatar
fordlovin
How much are they usually? Do they just go out like that?
Old Sep 28, 2006 | 02:28 AM
texan2004's Avatar
texan2004
I doubt they cost very much. I'd be surprised if the switch was more than $15.00 or $20.00. Yes, they can go quickly. If it were me, I'd check the switch with a multi-meter first to confirm that is the problem. Could be a blown fuse or fayed wire though the switch would be what I would bet on beg the problem.
Old Sep 28, 2006 | 02:45 AM
Torque1st's Avatar
Torque1st
Posting Legend
If you are hearing a clicking noise it may be the plastic clutch unit in the motor gearbox. They go out with regularity. Replacement motors are available or there is a simple fix that involves nylon rollers or 3/8" ball bearings. You can find the fix with a search.
