ARP Head studs.
Old Sep 27, 2006 | 08:47 PM
Rangercrt76's Avatar
Rangercrt76
ARP Head studs.
I have a 04 PSD Lariat with 45,000 on the dot and I noticed thanks to everyone on here that I had a possible head gasket problem and didn't even know it. This sight is great and I would like to think everyone!!! I have a aftermarket exhauste and intake that came with the truck when I bought it and I took it to me local Ford dealer and they wouldn't work with me they just wanted to put a new coolant bottle on it and push it out side. I stressed to them that I had a warranty on it form the place I bought it and if it had a head gasket problem that I wanted them to test for it and I can get it taken care of. I picked my truck up and they got me for 2 hrs labor for $112 and then took me for $75 bucks for the coolant tank that the truck didn't even need because it had bad head gaskets. I don't know why the tech wouldn't work with me he told me that the powertrain warranty didn't apply to me and that my truck runs to good and that it has a chip in it. Little did he know that I have a friend at the local Mercury dealer that scanned the computer and the truck came back as stock. Why wouldn't they check for me or even work with me at all? I found a dealer a 120mi away from me that would touch my truck and I told they on the phone that it had a intake and exhauste on it and they called me a couple of days later and said they are putting head gaskets in it. I bought ARP studs and was wondering if there is a certain way they have to go in?is there any certain torque sequence? I was told by someone to go center out and go 125LB than 250LB is this correct please let me know thanks Chad.
Old Sep 27, 2006 | 09:38 PM
Maxium4x4's Avatar
Maxium4x4
The studs will only go in one way if that is what you were asking. Do a 3 step sequence increasing torque working from the center of the head out and tighten to a finished torque of 240lbs using the proper lube on the stud threads.
