embarassing wheel squeek
Old Sep 27, 2006 | 04:30 PM
xTritonV10x's Avatar
xTritonV10x
my truck (1990 F350) has recently started squeeking again, it has happened before but it went away. I believe it is coming from the front drivers side wheel, brakes are new, and I tried cleaning them but that didn't work. It's not really high pitched, more of a whine. Any ideas?
Old Sep 27, 2006 | 05:24 PM
Rusty90's Avatar
Rusty90
Does it go away if you take a right hand turn or get stronger when you make a left hand turn? If so, it may be your wheel bearings.
Old Sep 27, 2006 | 09:40 PM
Fordman_Evs's Avatar
Fordman_Evs
Check your serpentine belt mine started to slip when it was cold and I thought it was my wheel bearings. Changed the belt and tensioner pulley and she was good to go.
Old Sep 27, 2006 | 10:47 PM
xTritonV10x
belts are good, the closest thing I can think of that sounds like this noise, is a seagull, as ridiculous as that sounds. I believe it stays the same regardless of turning, but I will look into it. Thanks
