lifter question
Old Sep 27, 2006 | 02:27 PM
mxer289's Avatar
mxer289
rocker question
Does anyone make a roller rocker for 460 heads that dont require screw in studs and guide plates? I was also wondering if my springs would bind if i went with lunati's voodoo cam with a .600 lift on the exhaust with stock rocker ratio.
Old Sep 27, 2006 | 02:34 PM
monsterbaby's Avatar
monsterbaby
Answer to both questions is yes, crane and FRPP both have a bolt down type rocker, and yes your springs will bind with a .600 lift cam (and personally I wouldn't run the bolt down style rockers with that much lift but thats just me)
Edit sorry I can only find the FRPP version, the part number is M-6564-C351, and it's the stock ratio
Old Sep 27, 2006 | 02:38 PM
mxer289's Avatar
mxer289
well thanks for the info..what cam and rockers would you run. Im going to put this engine in my 56 f100 street rod.
