headlights/dash dimm at idle
Old Sep 27, 2006 | 12:34 PM
slanteyye's Avatar
slanteyye
then brighten when accelerated.......alt prob? or volt reg.?
Old Sep 27, 2006 | 04:00 PM
Franklin2's Avatar
Franklin2
Is this the 1985 van? If so, there are some things to check;
1. Idle speed. Is it to the spec on the radiator sticker?
2. Belt tension/pulley condition.
3. Alternator health. Rev the engine while holding a voltmeter on the battery terminals. You should get about 14.5 volts. If you get something like 13, you may have a bad diode in the alternator. The local parts store tester may pick this up too if you want to have them test it.
Old Sep 27, 2006 | 11:21 PM
slanteyye's Avatar
slanteyye
Thumbs up thx..fixxed..
brand new alt=bad diode go figure....2nd replacement alt. w/another brand new bad diode..WTF?....3rd times the charm and all is well....thx
