Sponsored by: Real Truck
second gear
Old Sep 27, 2006 | 05:03 AM
marcus13's Avatar
marcus13
second gear
I have a 2002 5.4 superduty long bed super cab 4x4 off road, when accelerating first gear is normal, then second gear right at 3000 rpm the rpm's fall to 2800 and the go normal againand the 3rd and 4th are normal, why is this
Old Sep 27, 2006 | 06:44 AM
Casey's Avatar
Casey
It's the torque converter locking. It's normal.
Old Sep 27, 2006 | 10:34 AM
biz4two's Avatar
biz4two
Arrow
Welcome to FTE!
Agree with Casey. Totally normal and is the torque converter...
biz
Old Sep 27, 2006 | 06:28 PM
marcus13's Avatar
marcus13
thanks guys, is there any way to stop it
Old Sep 27, 2006 | 08:48 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Consider it an extra shift. There's nothing wrong.
Or is the vehicle actually slowing down or the engine bucking when it does this?
Old Sep 28, 2006 | 05:22 AM
marcus13's Avatar
marcus13
its just that you can hear it in my exhaust, would the power programmer remove it
Old Sep 28, 2006 | 08:48 AM
krewat's Avatar
krewat
You must have a pretty loud exhaust
My v10 does it all the time.
I just pretend I have a TorqueShift and 5 gears
Old Sep 28, 2006 | 09:30 AM
captchas's Avatar
captchas
Guest
programer no it will not! it's normal to feel the converter lock up and rpm to go down.i fully agree with the other guys
Old Sep 28, 2006 | 10:04 AM
derherr65's Avatar
derherr65
Not to go too far off topic here, but what's with all the superdutys running the 5.4? My '65 Mustang's engine is nearly that big. It can't be a good towing engine, can it?
Old Sep 28, 2006 | 12:25 PM
biz4two's Avatar
biz4two
Arrow
(just kidding)...
The 5.4L is a "good" engine to tow with...as long as you stay within the specs. YES, the V10 and PSD engines are "better" to tow with, but the 5.4L is "good". Also helps to have low gears...makes that 5.4L seem like a larger displacement engine.
biz
Old Sep 28, 2006 | 12:31 PM
krewat's Avatar
krewat
The difference is:
1) Much longer stroke - the stroke is bigger than the bore.
2) OHC - better breathing, stock.
3) Much less internal friction.
To me, the 5.4 is basically an FE 360. And lots of people towed with those things
Old Sep 28, 2006 | 01:14 PM
derherr65's Avatar
derherr65
350-365ftlbs and 260-300HP depending on year and number of valves. That's a bit better than I thought it had. Though I hear 12mpg is common for the 5.4, and we get 13.5 from our V10.
As for marcus13's problem... you could get a programmer and reprogram the computer to shift or lockup differently. I'd bet it's not worth the cost though.
