I need your help!
Old Sep 27, 2006 | 02:05 AM
1987_f150's Avatar
1987_f150
Exclamation I need your help!
Anyone that can send me a picture of their 84 f150 with the 302 2bbl would be really helpful right about now...I need to run new vacuum lines but most of the original are split going other places or capped off. (top end without the breather attached)
There is a map below the hood but its all confusing to me...
I need to get this truck running by the end of the week...dad is taking his car back and told me I need to get this on the road.
PAH-LEEZZZ HELP ME OUT HERE!!!!
Thanks.
Old Sep 28, 2006 | 12:12 AM
Mil1ion's Avatar
Mil1ion
Had you put the topic in the title I would have looked at this earlier.
Please put the topic in thread titles
You didn't list enough info abou the truck.
The best is to post the claibration code or engine Identification code from the valve cover sticker.
It should be 3 letters in the very bottom left hand corner of the decal.
There are so many different calibration codes (that change hose routing) a poerson has to know what the code is and for that they need this info:
Model Truck
Engine Type
Axle ratio
Transmission type
Operating local (49 state or calif)
Once you get me that info......I'll help
Old Sep 29, 2006 | 07:37 AM
1987_f150's Avatar
1987_f150
1984 F150 XL 4x2
302 Carbed 2 bbl motorcraft
dont know ratio...AOD
operating??? not sure what that means but Ill put Pennsylvania
Old Sep 29, 2006 | 08:53 AM
Sport45's Avatar
Sport45
I've got an '83 F100 similarly configured. If the "map" you mentioned looks like this I might be able to help.
Old Sep 29, 2006 | 01:32 PM
Mil1ion's Avatar
Mil1ion
I need the three letter code from the lower right hand corner of that decal..
There are 22 different diagrams for a 1983-84 302.
Old Sep 30, 2006 | 11:13 PM
locknkey's Avatar
locknkey
The way to understand these diagrams is simple, each hose has a connection, each connection goes to a part, you will notice what some of the parts are, traced them out first, then each one check to make sure the hoses are good and tight, and relace any that you think could be bad or leaking, hoses that are old and dirty, oiled soak and split should be replaced. You want to make sure everything is snug and tight. Don't glue the ends to the parts or put any wire or clamp on them. They are desiged to be tight but not easy to pull off, snug is what you want.
Be patient and trace every hose to its proper place, if you don't know where something should go, ask here and we'll help you locate it.
Old Oct 1, 2006 | 11:31 AM
beaners1's Avatar
beaners1
Ok not to rob your thread but I also need help with this, could someone explain what the letters mean on the diagram? For example what is a A/CL CVM or a VCV.
Old Oct 2, 2006 | 07:45 PM
1987_f150's Avatar
1987_f150
yea yea yea explain them abbr.s im lost trying to figure out what vcv and some other ones mean
Old Oct 3, 2006 | 09:04 AM
Sport45's Avatar
Sport45
I'll give it a try. Maybe someone more knowledgeable can fill in the blanks and correct my mistakes....
A/CL DV - Air Cleaner Diverter Valve
A/CL CWM - Air Cleaner __________?
V REST - Vacuum Resistor
A/CL BI MET - Air Cleaner Bi-Metallic (air temperature controlled valve)
VCV - Vacuum Control Valve (usually coolant temperature controlled)
EXH HCV - Exhaust Heat Control Valve
VRDV - __________?
INT HCV - Intake Heat Control Valve
EGR - Exhaust Gas Recirculation
FLTR - Filter
MAN VAC - Manifold Vacuum
VCK V - Vacuum Check Valve
DIST - Distributor
CARB - Carburetor
C - _______? (vacuum source for A.I.R. System)
BV - Bowl Vent
TCP - __________?
PV - Power Valve
T - __________? (ported vacuum for distributor advance)
TVS - Temperature Vacuum Switch
SV-CBV - Solenoid Valve Carburetor Bowl Vent
VRDV - __________?
TVV - _________?
AIR BPV - Air Injection Reactor Bypass Valve
PURGE CV - Purge Cannister Control Valve
Old Oct 3, 2006 | 03:53 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Here is a great Automotive Dictionary.
http://vvvvvv.odessa.ua/
If you put in the Smog part Abreviation, such as VRDV in the search box, it will tell you what it means.
If you look at your Vac Diagram, it will show sketches of the parts, in the relative area where the part is located, Front back, left right, etc... Look around the engine in the relative area shown on the diagram until you find the part.
If you can't find the part, it is a good chance that it may have been removed.
Good luck!
Old Oct 3, 2006 | 06:01 PM
1987_f150's Avatar
1987_f150
only thing i found on the sticker with 3 letters is APD above it has E4AE 9C485 mean anything?
Old Oct 3, 2006 | 06:15 PM
Mil1ion's Avatar
Mil1ion
That APD number is useless.That's a decal number
Do you also have a yellow or white sticker on the valve cover ,,that has a UPC code on it ?
You can find some of those abbrevations defined here.
http://www.clubfte.com/users/mil1ion...mDiagrams.html
Old Oct 3, 2006 | 07:05 PM
1987_f150's Avatar
1987_f150
nope nothing on valve cover
