inoperable brakelights
Old Sep 24, 1999 | 10:12 PM
Tom1.0's Avatar
Tom1.0
The brake-lights on my 65 F250 went out. The fuse is fine, power is coming to and from the brake-light switch. Power is coming to the tail- lights and turn signals, but no power to the brake lights. I had the instrument panel off of the dash before they went out. Is there any connections around the dash that I may have loosened? I do not have a wiring schematic, so all I see is a bunch of taped up wires. Any help would be appreciated.
Old Sep 25, 1999 | 07:31 AM
jowilker's Avatar
jowilker
Tom you have a ground problem. You have only two wires to the light so brake and turn use the same one. If a new bulb wont do the trick, try a battry post brush into the socket, unplug the wire connector a few in. back and clean it. Don't have a good answer for you, but know what the problem is, you will just have to find it.
Good luck
John
Old Jan 18, 2001 | 06:48 PM
66merc's Avatar
66merc
Old Jan 18, 2001 | 07:30 PM
jbman100's Avatar
jbman100
Tom,
Something else you might check is the brake light switch. I have a 65 F100 and when I first got it I had to lean on the brakes to get the lights to come on. Changed the switch and now I just have to barely move the peddle to get them lit. Hope this helps
Old Jan 18, 2001 | 08:21 PM
66ranger's Avatar
66ranger
The tailight housing itself should have a good ground at where it screws to the bed. I had to clean this up, as well as repair some splices. Later, after bleeding the brakes and master cyl, I found the brake lights didn't work. Got a new switch for $ 3.99 and everything works fine again. Good Luck!
Old Jan 18, 2001 | 09:21 PM
oldfordsidestep's Avatar
oldfordsidestep
I have to realy push on my brakes to get the lights to work also. Were is the brake light switch?? I have been following wires trying to find it but with no luck. And where do you get new ones
Old Jan 19, 2001 | 10:16 AM
66worktruck's Avatar
66worktruck
try this: http://www.wire-works.com/H1.asp
Old Jan 19, 2001 | 10:36 AM
hpguy's Avatar
hpguy
The switch should be right above the outlet on the master cylinder:
https://www.ford-trucks.com/dcforum/User_files/3a687ad07f51134e.jpg
(Picture from the 1964 Ford Truck Shop Manual)
-Andrew
f250_64(No Email Addresses In Posts!), same for yahoo messenger
Nothing, and I mean nothing, stirs the soul, saying I'm a bad **** like lettin'em rip with a window shaking, fuel gulpin, carbon monoxide belchin, attention gettin, V-oh my LORD!-8!
Old Jan 19, 2001 | 12:08 PM
glindley's Avatar
glindley
Andrew, I believe in '65 Ford went with a brake light switch under the dash on the pedal arm itself..
Gene
Old Jan 19, 2001 | 12:32 PM
jowilker's Avatar
jowilker
Gene I disagree, that is the correct setup.
John
jowilker
Club FTE since 01 01
66 F100s
In the still cool hours of the night,
you can hear chevys rusting away.
Old Jan 19, 2001 | 02:00 PM
jbman100's Avatar
jbman100
Nope the brake light switch is just where it is shown on the above diagram.
Old Jan 19, 2001 | 03:21 PM
StockMan's Avatar
StockMan
[font size="1" color="#FF0000"]LAST EDITED ON 19-Jan-01 AT 04:34 PM (EST)[/font][p][FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
Andrew has posted the correct picture for this series. The same set-up was used through the '66 model year. In 1967, Ford changed to the dual reservoir master cyl. at which time the brake light switch was mounted on the pivot bolt at the pedal.
[/FONT]
[LINK:www.hometown.aol.com/tbeeee|http://members.aol.com/tbeeee/page/registrysig.gif]
Old Jan 19, 2001 | 06:51 PM
trouble's Avatar
trouble
As John said sounds like a ground problem .Make sure your ground strap is not broke from bed to frame. Grounds cause many of hours of work and headaches.
Trouble
Old Jan 19, 2001 | 08:08 PM
66ranger's Avatar
66ranger
According to my trusty Mac's catalog, the brake light switch is the same for the 48-66 models. '67 uses a different part from the 68-72 models, however..
Old Jan 19, 2001 | 10:28 PM
StockMan's Avatar
StockMan
