what should eng temp be
Old Sep 25, 2006 | 10:54 PM
arsp1's Avatar
arsp1
when i have a heavy load like sheet rock the temp eeads on the high side should i put a real temp guage in the i cleaned everything up real good and i dont trust the stock guage also put new thermostat in also thanks
Old Sep 25, 2006 | 11:27 PM
PLC7.3's Avatar
PLC7.3
Was the new tstat a Ford or IH..........
Diesel engine coolant temperature at the top of the radiator where hose attaches after high rpm or under load condition for 20 minutes should be (195-237*F) 91-114*C nice time to have a temperature reading point and shoot tool.
CAUTION:
The specified/required thermostat does not contain an internal bypass, since the bypass is located in the cylinder block. Whenever the thermostat is replaced, it is mandatory that only Motorcraft E5TZ-8575-C or Navistar 1807974C94 thermostat be installed.
CAUTION:
Do not attempt to repair any thermostat. It should be replaced if it is not operating properly.
Check the new thermostat before installing it for correct opening temperature. Before suspending in boiling water, with a flashlight check where the rubber and the flat metal flange meet for bad seal. Tstat should start to opening barely at 180-192f, fully open 200-212f, allow to cool and check for rubber seal again.
Removal: Disconnect batteries, drain 4+ gals A/F, remove: as required, fan belt, alternator set aside, alt bracket, remove filter support from fuel filter then e/block. Disconnect upper rad hose at rad, remove tstat bolts and housing. Clean both faces, depression and holes in block, ensure check ball in goosekneck is clean, free and rattles "do not remove".
Installation is reverse proceedure, I do not use sealant on gaskets and faces. REMEMBER the tstat pellet(copper end) goes into the block. I do use a "very small amount" of sealant on the edge of the tstat face when installing into the recess, now go for coffee, allow sealant to setup, this has saved me from tstat slippage when the gasket and goosekneck are installed. Replace all items in reverse order......
Manifold bolt torque......... 20ftlbs
Old Sep 26, 2006 | 12:32 AM
arsp1's Avatar
arsp1
oh i better change it thanks i want this motor to last a long time thanks
Old Sep 26, 2006 | 10:14 AM
Hamberger's Avatar
Hamberger
rsp1,
How old is your truck?
Are you running the OEM radiator?
Radiators do plug off over time and you usually find out that it no longer provides enough cooling when you pull a heavy load.
If rad and Tsat are fine than take a look at your fan clutch, maybe it is starting to slip and is no longer providing enough air flow across the radiator.
Seb....
Old Sep 26, 2006 | 07:22 PM
bc6.9's Avatar
bc6.9
Those temp guns are great, we use them at work all the time.
Old Sep 27, 2006 | 02:20 PM
arsp1's Avatar
arsp1
the drive train from the rear to the radiator and wiring harness is from a 90 e350put into a 80 e350 lot of work it was
