65 F250
Old Feb 4, 2001 | 09:35 PM
pntrbil's Avatar
pntrbil
65 F250
My Dad recently GAVE me his very original 65 F250. Great old truck! Man, they made 'em outa steel in those days.
Here's what I know so far. 352, 4 speed (granny low for pullin' trees), some kind of PTO (power take off) on the trans, Dana 60 rear end.
Non original equipment is 2 nicely plumbed 15 gal sidetanks so it carries 46 gals of gas. It needs it too!
What it really needs is a paintjob but first I'll need some window rubber and the gas tank donut. Anybody know a good source?
Any options on gearing for that Dana 60?
Do I really wanna go 75 with a twin I beam? LOL!
Bill
Old Feb 5, 2001 | 06:01 AM
jowilker's Avatar
jowilker
65 F250
Bill sounds like you got a great heavy duty truck there. That truck was a special order with the pto.
You can find a 75/76 with a 360 in it and harvest the parts and you can put power steering and disc brakes on the old truck, maybe a C-6 if you don't need all that tranny.
What do you mean run 75, I will run mine on past 100 mph with confidence in the truck.
John
jowilker
Club FTE since 01 01
NC Chapter
66 F100s
In the still cool hours of the night,
you can hear chevys rusting away.
Old Feb 5, 2001 | 06:44 AM
pntrbil's Avatar
pntrbil
65 F250
100 mph? LOL! Maybe my Twin I Beams are a little loose!
It's a fine old truck tho. Definitely a keeper. One thing about the 4 speed and steering it has now is I don't have to worry about the wife borrowing it.
You guys might find this good for a laugh. My Dad was the 2nd owner and between the 2 of them they always kept a camper on it. So you'd think I need a tailgate? No. They saved it since 1965! It's perfect!
Could definitely use a taller rear gear tho. I've been cruisin' the archives and a 9 inch swap for the Dana seems to be common but I'd like to keep the heavy 8 bolt axles on it. I suppose original or not is a common dilemna around here. Modern convenience or the nostalgia?
Richmond Gear has gear sets for the Dana but I think they're for the drag racers. Nuthin' below 3.50.
John, I spotted a pic of your truck at the Slick 60 Club site? Looked real nice. What kinda power train you runnin' to get a 100 out of it?
Bill
Old Feb 5, 2001 | 08:46 AM
supercub's Avatar
supercub
65 F250
I have a F-100 and it has the 4 speed with the granny and the 60 rear end. I have been looking into getting a "taller" rear end,(lower number). That rear end had a ratio of 3.73 to 1. Mine is 4.10 to 1 which makes 50 mph seem like 90 mph.
Monty
Old Feb 5, 2001 | 10:29 AM
artskyd's Avatar
artskyd
65 F250
Bill, I have a 65' F-250 and I changed the rear ratio from 4:10 to 3:54, that's the lowest I could find for that year Dana rear end.I also looked at swaping out the whole unit, but found that spring perches and shock mounts changed through the years and I had a hard time finding a good donor.With the 3:54 rear I can cruise at 60 mph at about 2,400 rpm.
BTW anyone know a good source for the spedo gear in the trans.?
Mine is a little off since I've changed rears. I have the 4-speed granny low.
artskyd
Old Feb 5, 2001 | 11:07 AM
Charles-65F350's Avatar
Charles-65F350
65 F250
>It needs it too!
Where did your dad get these tanks? I want to do something similar on my '65 F-350.
-Charles
ps what size tires are you running? My truck has the same trans and 4.88 gears, and turns 3025 rpm at 60 mph (235-85R16 tires).
Old Feb 5, 2001 | 12:23 PM
jowilker's Avatar
jowilker
65 F250
Bill, I have a warmed up 352, C6 and 2.75 rears. I wouldn't be afraid to speculate that it would hit 130 or better. It has plenty left at 100 mph. I aint itching to find out though.
I love my wifes husband.
John
jowilker
NC Chapter
66 F100s
Old Feb 5, 2001 | 01:39 PM
skip4274's Avatar
skip4274
65 F250
Bill.
Get all the rubber parts (and others too) you need from Dennis Carpenter Reproductions 1-800-476-9653 . The catalog for your truck is only $3 and is well worth the money. You can also check LMC Trucks, Sacramento Vintage Ford for other hard to find parts, and John Wilkerson has a buddy at one of the better parts shops in North Carolina. I think it is Carolina Classics. I'll bet he will give you the name and number
Glad to have you in the fraternity.
Skip4274
4everFord
Old Feb 5, 2001 | 09:56 PM
pntrbil's Avatar
pntrbil
65 F250
Artskyd, 3.54 sounds like a decent ratio in the Dana. I guess I'm comparing with a Chevy work van I have that was higher than I liked at 3.42. But that's with 235/75/15's. The old Ford has 16.5's on the back mounted on what my Dad calls "duplex" rims. Other than being kinda wide they look like regular 8 lug jobs to me.
The front has 16" wheels but may not be original? All big bias tires BTW. I hear 16" radials are way to go.
Charles, I have no idea where the saddle tanks came from. I would guess a small custom shop run by a guy who knew what he was doing. It's a real clean installation. The valve to switch between the 3 tanks is on the floor near the back of the cab on the driver's side where it's easy to reach. Not only is it clearly labeled there's a switch on the dash to light the general area up so you can see to switch the tanks on the fly at night! LOL! It's a cool truck. I like it a lot.
Good tip from John on the front discs too. Them drum brakes remind of the days when I was learning to drive. When I got in a car with "Power Brakes" I used to think they were too touchy. You just need to use some leg on them drums! LOL! Discs would be better tho. I'll keep an eye out for a donor for sure.
Bill
Old Feb 5, 2001 | 10:15 PM
truckfarmer's Avatar
truckfarmer
65 F250
djbonsu
Jan 12, 2021 01:59 PM
SD40-2
Dec 29, 2016 09:16 AM
Sean Balboni
23
Apr 9, 2013 08:02 PM
kilich
Apr 1, 2011 08:11 PM
adam83
Sep 1, 2009 06:14 PM
