Bent I-Beam
Old Feb 12, 2001 | 05:56 PM
66_390 mike's Avatar
66_390 mike
Bent I-Beam
Hey guys I have a question about straightening a slightly bent I-Beam. I have been searching for the answer to my alignment problems for almost a year and couldn't find anyone with the answer until last night. A friend told me that the I-beams could be bent to adjust alignment and that a poor job could have messed it up. I jacked up the front end to allow the suspention to sag and there it was! The passenger's side I-Beam is bent about an inch back right in the middle. So now, without going to an alignment or front end shop, how can I bend it back with out hurting anything else? How hard is the steel?
thanks,
mike
Old Feb 12, 2001 | 06:48 PM
Willie's Avatar
Willie
Bent I-Beam
Mike,
The I beam alignment process is a delicate proceedure by experienced frontend specialists. Generally when the I-beam has to be bent there is a special tool clamped onto the I-beam to put stress in the direction to be bent. Then heat is very carefully applied. If it is not done correctly then you can end up with a situation like you have. I would recomend that you find a frontend alignment shop that has the needed experience to do the job well. The other option is to replace the whole I-beam with one from a donor truck that has good alignment if you can fine one. I know that there are several guys that are upgrading their 1961-1966 Ford truck to front disk brakes and are replacing the whole I-beam with the disk brake rotor attached.
Just some thoughs to consider.
Old Feb 12, 2001 | 07:36 PM
66ranger's Avatar
66ranger
Bent I-Beam
Willie is correct, don't try to align a bent I-beam at home. I would go to a ford dealer if alignment is your choice.If you can find one, just get a SET from a doner truck. I think if you leave the king pins in, and swap the set from the doner, it won't be too bad. Don't forget, if the i-beam is bent, other suspension parts may need some help too..Good Luck
Old Feb 12, 2001 | 08:58 PM
jowilker's Avatar
jowilker
Bent I-Beam
Mike, I use a large local tire dealer, and they offer the I-beam alignment and had to bend one of my beams after I swapped in a 76 upgrade to my 66 F100. As stated by the other guys, leave to the professional.
John
jowilker
Club FTE since 01 01
NC Chapter
66 F100s
In the still cool hours of the night,
you can hear chevys rusting away.
Old Feb 13, 2001 | 05:59 PM
66_390 mike
Bent I-Beam
I think I will take your advise and seek a professional. Next project is the transmission.
Thanks,
mike
Old Feb 14, 2001 | 11:48 AM
pntrbil's Avatar
pntrbil
Bent I-Beam
jade79
Feb 17, 2017 01:21 AM
Napolean
Dec 24, 2016 05:47 AM
fatheroftwo
16
Dec 9, 2016 03:01 AM
robotunderpants
Oct 17, 2016 03:39 PM
1972RubberDuck
May 11, 2016 02:25 AM
