Cruise Control Quit Working
Old Sep 24, 2006 | 09:10 PM
BLK 96's Avatar
BLK 96
Question Cruise Control Quit Working
Hello Everyone. Has Anyone Had Their Cruise Control Quit On Them? I Checked The Fuse Under Dash But It Was Good, That Was All I Looked At So Far. Any Help Would Be Apreciated.
Old Sep 24, 2006 | 09:31 PM
RubberDuck's Avatar
RubberDuck
Anything else acting funny? OD light flashing, speedo acting funny, etc. If so I would say vehicle speed sensor on the top of the rear axle. Other than that, I don't know.
Old Sep 24, 2006 | 10:19 PM
BLK 96's Avatar
BLK 96
No Thats The Only Thing Not Working
Old Sep 24, 2006 | 11:33 PM
johnstoys2's Avatar
johnstoys2
Do your reverse lights work ? if not the fuse under the hood is blown. this same fuse also works the trailer battery charge relay. that's what was wrong with mine .
Old Sep 24, 2006 | 11:34 PM
tanglewood16137's Avatar
tanglewood16137
cruise problems
Well all i can say is mine does it on and off and i haven't figured it out yet.The darn thing is erattice works a frw ties then next time it dosent then it works again.
Rod
Old Sep 25, 2006 | 05:02 AM
Cuda_jim's Avatar
Cuda_jim
BPA switch on the master cylinder may be going bad. Unplug it and check for continuity on the switch. No continuity=bad switch.
FYI: The BPA is the subject of a recall that may cause fires.
Old Sep 25, 2006 | 08:45 AM
plowhand's Avatar
plowhand
Playing in the Dirt
Check your third brake light and wiring. If you have a burned out bulb in the third brake light, the cruise will not engage. Also if you have a bad connector there, it will not engage.
