Coolant leak
Old Sep 24, 2006 | 06:35 PM
hush210's Avatar
hush210
Coolant leak
I have coolant leaking out of the front timing cover on my '91 302. What did I break? Is this a big problem, or sumthin I can fix?
Old Sep 25, 2006 | 06:38 AM
cujo8's Avatar
cujo8
Most likely it is your water pump that is leaking. You might also want to look into replacing your timing gear set at the same time, depending on how many miles you have on the engine.
Old Sep 25, 2006 | 07:39 PM
hush210's Avatar
hush210
It has about 160k. how long do they normaly last?
Old Sep 25, 2006 | 07:50 PM
WarWagon's Avatar
WarWagon
about 159,987 miles...................just kidding, It would be a good idea to replace it.
