A4LD trans ?
Old Sep 24, 2006 | 12:40 PM
rsillmon's Avatar
rsillmon
Question A4LD trans ?
i have a 89 ranger that leaks trans fluid off and on, it has a 2.3 engine. the problem is i was told that the spacer on the back of the crankshaft could be cracked or wore out that centers the converter. they sell a new improved spacer for the 2.8, 2.9, and 4.0 engine did not see a listing for 2.3, anyhow assuming its the same, when i looked at, it looks like its part the crank, is it press on or the 2.3 is part the crank?thanks
Old Sep 24, 2006 | 04:53 PM
fordfaninIL.'s Avatar
fordfaninIL.
If you unbolt the flywheel, the spacer should come off with it. They are two seperate pieces, at least they are on the 4.0's.
