65 72 wireing
Old Sep 23, 2006 | 10:38 PM
passengass's Avatar
passengass
Cool 65 72 wireing
putting a 72 column in my 65.72 wireing is not the same could someone help
match them up. thanks
Old Sep 23, 2006 | 11:37 PM
airharley's Avatar
airharley
Do you have the wiring schematic for the 65? If so you can use a multimeter to shoot the wires on the column to see which ones have continuity between wires when you use the turn signal. Remember there is a single power wire for both turn signals. To find the horn contact the black lead (-)to the body of the steering column, red lead to the remaining wires and press the horn. The flasher switch will have a single lead that is the power wire. It uses the existing turn signal wires to flash both sides. Ignition wire are the same deal as the turn signals. I hope this helps more then confuses.
Old Sep 24, 2006 | 07:56 AM
banjopicker66's Avatar
banjopicker66
Written by George Selby, sent by John Wilkerson:
67-72 steering column pin out.
Big Connector:
White/Blue stripe: Right Front Turn Signal/Indicator on Instrument Panel
Green/White Stripe: Left Front Turn Signal/Indicator on Instrument Panel
Blue/Yellow stripe: Ground for horn
Red/Black Stripe: Brake Pedal Switch (12 VDC when brake pedal is depressed.
Blue: Turn Signal Flasher (Provides 12 volts to Turn Signals)
<o></o>Little Connector:
<!--[if !supportLineBreakNewLine]-->
Green: Right Rear Turn Signal/Stop Lamp
Yellow: Left Rear Turn Signal/Stop Lamp
Connect the following color wires together.
White/Blue Stripe on steering column: Connect to White/Blue Stripe on big connector
Green/White Stripe on steering column: Connect to Green/White Stripe on big connector
Black/Red Stripe on steering column: Connect to Red/Black Stripe on big connector
Blue on steering column: Connect to Blue on big connector
Yellow/Black Stripe on steering column: Connect to Green on little connector
Light Green on steering column: Connect to Yellow on little connector
Old Sep 24, 2006 | 11:01 AM
airharley's Avatar
airharley
Wow I was way off. Sorry about that. I'm going to flog myself now.
I wouldn't have thought there'd be that many wires running out of the column.
Old Sep 24, 2006 | 12:16 PM
jowilker's Avatar
jowilker
Mark what is really way cool, about halfway through that self flogging, start feeling a little sorry for yourself, and ask the wife to finish it for you.
John
Old Sep 24, 2006 | 01:06 PM
banjopicker66
Not so fast John. Have pity on the poor guy.
I rather suspect something on the order of "30 lashes with a wet noodle" or some other punishment equally severe.
Old Sep 24, 2006 | 03:29 PM
airharley's Avatar
airharley
Well I am done floggin myself. I did a bunch of honey dos like the lawn and laundry of all things.
Old Sep 24, 2006 | 06:30 PM
passengass's Avatar
passengass
thanks for the help. hope to get moor done on monday its getting close.
