radiator 51
Old Sep 23, 2006 | 04:01 PM
smityrods's Avatar
smityrods
radiator 51
i have question if you can take the flat head 8 radiator and plug one of top and the bottom holes so i can run a 351 windser?
Old Sep 23, 2006 | 04:35 PM
OldgreenF1's Avatar
OldgreenF1
I would say no. I mean you could possibly braze up two of the hose fitting but it would look like a nightmare.
I just saw a guy on one of these boards selling radiators $50 to $100
Old Sep 23, 2006 | 05:21 PM
smityrods's Avatar
smityrods
what other would work ?
Old Sep 23, 2006 | 05:28 PM
49willard's Avatar
49willard
When I bought my 49 in the 70's, it had one port on the bottom and one on the top blocked off and it ran a 56 nailhead Buick. It worked fine, cross country flat towing a Model A in hot weather. However, I had just recored it at that time. I am not going to use that radiator since it is showing signs of the solder breaking down (white at the lower tube joints).
Old Sep 23, 2006 | 05:32 PM
OldgreenF1's Avatar
OldgreenF1
The six cylinder stock radiator has one opening top and bottom it should work.
IM going to try one on my 302 swap if it over heats I have the original for my engine I will make fit.
Old Sep 23, 2006 | 05:45 PM
havi's Avatar
havi
I'll have the Roast Duck
hose clamps and pvc pipe cap covers(the rubber black ones) I don't know if it would work, though, but it works on my home plumbing.
