How to read Transmission Codes?
Old Sep 23, 2006 | 11:45 AM
Ilikebigtrucks's Avatar
Ilikebigtrucks
How do you read transmission codes? Sorry - I did search but I didn't really come up with much. Everyone seems to already know how to do it
I was driving down the highway with cruise set at 60 for 5 minutes or so -- I took an exit and when I pulled away from the light the tranny shifted into second late and hard and the O/D light was flashing. I hope maybe it's a fuse. Anyhow - my fluid smells fine but it is high so I guess I'm going to drain a quart or so out of it today. Still, I guess I need to know how to get codes out -- hopefully it's not overheating or something stupid. It seems like it only locks the converter when the engine starts pulling -- which I rarely let it do.<O
Old Sep 23, 2006 | 03:17 PM
Cuda_jim's Avatar
Cuda_jim
Over full will cause the fluid to foam and make the TFT sensor (Tranny temp) code out causing your simptoms.
Take it to a tranny shop, they will read it for free. They want your biz, or Pull #9 fuse under hood and replace, this Resets the PCM, justy like pulling battery cables.
Old Sep 23, 2006 | 06:23 PM
Ilikebigtrucks
I pulled the return line and ran it for a few seconds... Showing about right for cold with the fluid at maybe 90* (Would make a good bath water temp) Drove it home 2 miles it and was still sitting right there at the in the middle of the cold mark and the fluid didn't feel much warmer. I did drain probably a 2 quarts out of it to get it to that level so hopefully it was just that it was a bit over-full.
RV-Dean
Feb 26, 2008 04:38 PM
FullMontie
1947 and Older Ford Trucks
Jul 17, 2007 07:43 AM
Doogie S
2004 - 2008 F150
Jan 31, 2007 01:36 PM
masonma
Apr 7, 2006 01:46 PM
