Fuel pump? Heeeeelp!!!!!
Old Sep 23, 2006 | 09:58 AM
Vaquero007's Avatar
Vaquero007
Angry Fuel pump? Heeeeelp!!!!!
After the truck died (97 7.3) I tried the fuel pump. Put a new one on and still wont start. When the truck died it made a lot of black smoke shudded and that was it. I dont think i am getting any diesel to the injectors as when itry to stars it no evidence of fuel aqt the exhaust. Any suggestions ? thank you. Broke Down in NM..
Old Sep 23, 2006 | 10:09 AM
Stroker 94 1/2's Avatar
Stroker 94 1/2
Have you checked all the fuses in the cab and under the hood? Do you get any smoke out the exhaust and what color is it?
Old Sep 23, 2006 | 10:24 AM
barancher's Avatar
barancher
Yes, we checked ALL the fuses and there is no exhaust...can you tell me where the CPS or fuel rail sensor are located? We've read on other threads that this may have something to do with the problem, but we're not sure where to find it. We've replaced both fuel pump and filter...we're at a loss as to what to look at next...thanks for the response!
Old Sep 23, 2006 | 01:01 PM
Cuda_jim's Avatar
Cuda_jim
The CPS is located about 10 oclock on the harmonic balancer. Here's some other sensors:
https://www.ford-trucks.com/forums/a...achmentid=2540
Old Sep 23, 2006 | 08:10 PM
whale45714's Avatar
whale45714
barancher you may want to have look at this it's a 7.3 brake down manual it has been a savior for me!!!!! http://www.nav-international.com.br/frame_master.asp?tipo=powerStroke&pg=manual_i/powerStroke/hs.asp it show a lot of good views of most every thing on the motor here is there homepage http://www.nav-international.com.br
Last edited by whale45714; Sep 23, 2006 at 08:29 PM. Reason: wrong address/ add home page
