Bronco II Ford Bronco II
I cant pass emission
Old Sep 22, 2006 | 11:39 PM
grizzle383's Avatar
grizzle383
Unhappy I cant pass emission
my 88 B2 wont pass emission they said i need a cat converter how hard is it to install one and any other tips to pass emissions?
Old Sep 23, 2006 | 02:51 AM
Help I M Stuck's Avatar
Help I M Stuck
i always put high grade gas in it and dump a bottle of octane boost in it and head to the emissions testing station..that always seems to do it for me. Either that or they are scared to dyno test it with 4 inch suspension lift, 3 inch body lift and 35x12.50x15 tires on it?
Old Sep 23, 2006 | 08:02 AM
OSin86's Avatar
OSin86
I tried every trick in the book and didn't pass untill I installed a new cat. The mounting studs were so rusted they were a lost cause so I torched them out and reinstalled the new unit with bolts. As soon as I got it installed I passed. Mines a 1990 and it's got one expensive converter! Total project cost was about $235. I believe the 88 cat is about $80 cheaper then the 90. I would think $150 would be closer for your project. Good luck.
Old Sep 23, 2006 | 06:56 PM
dmkolb's Avatar
dmkolb
I had this same issue on my 87 BII. I had to replace the bad cat, O2 sensor in the exhaust pipe and put in a brand new air filter. Make sure it's tuned up too.
I then passed easily.
Old Sep 23, 2006 | 08:09 PM
rebocardo's Avatar
rebocardo
I used a fuel additive called something such as Guaranteed to Pass available at Advance Auto Parts. Dropped all the test results well below what was needed to pass and all I did was add the gasoline additive.
