Sponsored by: Real Truck
Electrical Issues
Old Sep 22, 2006 | 03:37 PM
SBLG's Avatar
SBLG
Electrical Issues
For the past couple of weeks I seem to be having some issues with my truck hope this rings a bell with someone - kind of odd symptoms - so here goes:
2002 F-250SD Crew cab - 7.3 4x4
Problem - after starting my AM/FM radio will flash on and off some times only once some times multiple times rapidly at a random speed and amount - only at start up and for the next 15-20 seconds, after that all is well. Also on start up if I step on the brake same thing radio goes on then off quickly only once, and usually only the first time I step on the brake - after that it fine. Same with the wipers and the blinkers - turn them on radio goes off the on - today it seemed like with the blinker on, the radio would go on and off timed to the blinker for about three or four cycles then it was fine. Everything else seems ok - I have not noticed any other electrical issues or things going on then off - Don’t know of this is a glow plug relay issue on start up only, but then why the connection to the brake / wiper and blinker? Need ideas and help
Thanks on advance
Chris
Old Sep 22, 2006 | 03:55 PM
6L PWR's Avatar
6L PWR
I've never had that particular problem, but the times I've had electrical problems that were intermittent such as this, I've always found a bad ground. That's where I would start on this one at least. Take off the grounds from the radio and clean them up with some sandpaper and clean where they attach to as well. Good luck. Electrical troubleshooting is all about patience.
Old Sep 23, 2006 | 07:24 PM
SBLG's Avatar
SBLG
Question
Update - grounds seem ok - One each side of the engine block and a couple smaller ones in the feneder areas - and some behind the dash.
Today put a simple test light on the power going to the radio - when the radio flashes on and off I find no interuption in the power at fuse #11 ( 20 amp radio main) also only power at the 5 amp ( cant remember the #) when cranking. Now tonight it seems worse more on and off for a longer period of time - and the ABS light comes on.
Thanks
SBLG
Old Sep 23, 2006 | 07:45 PM
6L PWR's Avatar
6L PWR
Alrighty then. That's wierd. Have you tried to check the wires going from the fuse box up toward the radio and just under the dash itself for any areas that may have been rubbed. Sounds like possibly there might be a short. Not a dead short that causes the fuse to blow, but a slight short can cause power interuption such as that. If you just rub along the wire looms you should be able to feel any area that's rubbed through.
Old Sep 23, 2006 | 08:17 PM
pmbmax's Avatar
pmbmax
Thanks
SBLG
I did the young big stereo thing in the 90s lots of subs and alll the amps you can buy . We had all kinds of issues like that One thing i try to start with is unhook the antenna. and make sur you head unit is not touching any of the metal part of the dash frame. ( you can unhook the grounds and as long as you have a good sheild on the antenna it will work so see if it works with out the extra ground of the sheild ) also after that try running a wire frome the case of the head unit thru the door and out to the neg of the batt. see what happens. You will see a change in one are the other try that and post the results hope that helps Phil
Old Sep 23, 2006 | 09:15 PM
BigRigRV's Avatar
BigRigRV
I was having the same types of problems in my motorhome (ford chassis), the grounds are the problem. Save yourself a ton of headaches and get a grounding bar. Just bolt it to the chassis and connect all of your grounds to it. I'm in the process of doing this right now and need a e450 wiring schematic, anyone have one handy?
Old Sep 23, 2006 | 09:19 PM
BigRigRV's Avatar
BigRigRV
For the ABS issue, do you have OBDI or ODBII? If so, spend the 50 bucks and get a cable to hook up to your pc. http://obddiagnostics.com/ has a great tool, My instrument panel is toast and I'm using a p3 800 I had sitting around for my instruments...
Cheers,
~E
