Ontario Chapter Join Chapter>, Leader: loudfords
1984 inline 4.9l
Old Sep 22, 2006 | 10:20 AM
will2526's Avatar
will2526
Question 1984 inline 4.9l
hello,i have a 1984 f150,inline six cyl.tried to start,it turns over but won't fire,i've changed coil,ignition module,checked wiring harness,can anyone help?
Old Sep 22, 2006 | 10:46 AM
loudfords's Avatar
loudfords
Will,
You'd be better off asking this in the 80-86 truck forum. This forum is more for discussing Ontario events and such.
Welcome to FTE, and we hope you'll stick around!
(PS: are you sure you're getting fuel to the engine?)
Old Sep 22, 2006 | 08:38 PM
Dealford's Avatar
Dealford
Welcome To FTE !!!!!!
You'll find that the folks on the 80-86 forum are always willing to help out.
FTE also has the "Electrical Systems & Wiring" forum. If your problem goes deeper than the obvious, they can help you step by step to pin down the real trouble.
There's 90 some odd forums here at FTE. Along with absolutely tons of info on trucks and all the other stuff that's discussed in the chatter forums, there is a topic to please everyone......somewhere.
While you are looking things over here, click on anything that looks different & see where it takes you.
AL.
Old Sep 23, 2006 | 04:26 PM
truckfarmingcanuck's Avatar
truckfarmingcanuck
Hey welcome aboard,
Feel free to come back and visit us here in Ontario. The 4.9L is a great lil motor. I don;t expect it would take much to bring it to life. Where are you located?
Good luck
TFC
Old Sep 23, 2006 | 05:22 PM
Beast12's Avatar
Beast12
Good luck
TFC
His profile says Welland, ON.
-Matt
Old Sep 24, 2006 | 06:27 AM
truckfarmingcanuck
That's weird when I look up his profile all I get is "ON" for the state/province section and " Canada" for the country part. Do you have some moderator powers or is my view screwed up?
Old Sep 24, 2006 | 06:56 AM
Beast12's Avatar
Beast12
This is what I get when I look under Additional Information when I click his username and view profile:
First Name:
william
Last Name:
smith
City/Town:
welland
2 Letter State/Province (use "--" for outside USA/:
on
Country:
canada
Make:
Ford
Model:
F-150
Year:
1984
Maybe it's because I am "Super".
-Matt
Old Sep 24, 2006 | 02:44 PM
truckfarmingcanuck
Weird I don't get his name or town but the rest is the same?
Old Sep 24, 2006 | 03:00 PM
The_Archiprelate's Avatar
The_Archiprelate
Does it crank uniformly? Does the engine slow down when it's hitting the compression stroke like it should or does it seem to turn freely. If it turns too easily you could have low compression, check that too. Check that you're getting fuel, make sure you're acutally getting spark from the coil and from the distributor itself to the cylinders. Check the quality of your fuel and check your timing. This should give you a better indication of what's going on but I wouldn't suggest continuing to throw parts at it like you have been. Waste of money, waste of time, risky buisness. Hope this helps.
