Starter and Flywheel combo question
Old Sep 21, 2006 | 08:31 PM
apbmaliby's Avatar
apbmaliby
We're working on a '60 Ford truck that we put an '84 Ford 300 Inline six in. The problem is that the starter and flywheel do not mesh. When the starter gear kicks out, its just close enough to grind the tips of the ring gear teeth off. It is a 157 tooth flywheel. Do you think we have the starter for a 184 tooth flywheel? If so, what starter should we buy? (for what vehicle). Any other suggestions on what the problem could be?
