DTC code 9202
Old Sep 21, 2006 | 03:52 PM
Charles1's Avatar
Charles1
DTC code 9202
Ok, I have a code on the Navigator that is giving me a DTC 9202. I used the instrument cluster to do a self test to see if anything came up. What could cause this, and what do I need to do to repair it? Has anyone ever had this problem? Is it serious or not so bad?
<!--IBF.ATTACHMENT_182910-->
Old Sep 21, 2006 | 04:24 PM
pitrow's Avatar
pitrow
9202 is "Fuel Sender Open Circuit" sounds like you have a broken wire in the fuel sensor. Does your fuel gauge work?
Old Sep 21, 2006 | 04:42 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
If your fuel gauge is working and there is no check engine light, then don't worry about it. I see the "fuel sender" code set in a lot of ford vehicles. It just means at one time it had a "glitch" and to find and diagnose the problem at this point would be very expensive, if possible, as it's a intermittant problem (if you're showing no symptoms).
Old Sep 22, 2006 | 12:57 AM
Charles1's Avatar
Charles1
Fuel Gauge Works
The fuel gauge works and no check engine light.
Old Sep 22, 2006 | 12:59 AM
Charles1's Avatar
Charles1
It seems to run fine. I will just let it go for now. I was thinking it may have had something to do with the injectors or something.
Old Feb 11, 2022 | 09:51 AM
Ryemac84's Avatar
Ryemac84
I'm having the same issue the detc 9202 code however my fuel gauge is not working and I just filled the tank and my truck will only start and run for a minute then die out
clouden
Apr 29, 2025 02:49 PM
Shorty 66
1978 - 1996 Big Bronco
Sep 8, 2013 05:35 PM
the deno
Jun 21, 2013 01:53 PM
jonathan642
Feb 29, 2012 02:02 PM
lvmilkman2002
Mar 31, 2005 08:45 AM
