Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
fuel siphon
Old Sep 21, 2006 | 12:04 PM
Black-Lightning's Avatar
Black-Lightning
Angry fuel siphon
howdy,
i'm a newbie on this site. anyway, does anyone know if fuel can be siphoned out of a '04 svt lightning's fuel tank? my girl almost filled up my truck with regular.
i was wondering if i could use a small-diameter clear hose to remove the fuel. however, i'm not sure if i could damage any internal parts such as, fuel indicator, etc.
thanx in advance for any info you guys can provide. lightnings rule!
Old Sep 21, 2006 | 06:36 PM
cutlass79500's Avatar
cutlass79500
just go get yourself some good octane booster run the tank out just drive it easy if your worried about it. dont know if the hose would mess anything up but not worth taking a chance. I have worked with alout of gms that are supercharged some can even get away running regular with a cold t-stat as long as you drive it easy you shouldnt have any problems
Old Sep 26, 2006 | 01:28 AM
Stewart_H's Avatar
Stewart_H
You cannot thread the hose down the filler neck into the gas tank. There is a baffled cap about 6" down the tube that blocks syphon hoses from reaching the tank.
Octane booster would work, if you had the room in your gas tank to add the proper amount of booster. And you can't use the STP type boosters you find at Kragens or Autozone. Those over the counter "octane boosters" are junk and don't work. You'd need a true octane booster like Torco.
All you need to do is jumper your fuel pumps and drain your tank through a shrader valve on your fuel rail. I have an instruction sheet with pictures saved to a word document if you'd like me to email it to you.
This is the method used to drain most of the 91 octane from my tank so race fuel can be used. Then after racing, the race fuel is pumped back out at the 91 octane is put back in. No more wasted race fuel.
Lemme know if you want the Word doc.
Stewart
Old Aug 7, 2007 | 02:52 AM
bigdave1's Avatar
bigdave1
just run it.go easy on it, it should be fine
Old Aug 7, 2007 | 05:04 PM
Stewart_H's Avatar
Stewart_H
Big Dave, seeing as how this thread is just shy of a year old, I'm pretty sure he's already run through that tank of gas, or at the very least, taken care of the problem.
Stewart
